Hi guys; progress on building my new winder is on hold due to my outside work-space being rained upon so until the weather clears up, I guess the best I can do is some 'academic research'. Anyways, the other night I was looking at a topic on this forum (I can't find it now though) that was comparing the differences between old and new wire of which one of the key differences that stuck out with me was the old wire was slightly less conductive due to a less pure copper quality. Within the conversation, it was also pretty much concluded that within the standardization of the copper wire industry today it would be almost impossible to find a wire company which would be able to reduce the quality of their copper to satisfy a small niche market, especially when almost everyone else who uses copper magnet wire desires the purest quality possible for the price. This quandary got me thinking though; isn't aluminum wire by nature is less conductive than copper? I suppose the crux of the matter would be by how much is it less conductive, especially if the numbers are way off in comparison between old wire, new wire and aluminum wire. Would anyone here happen to have any first hand experience using aluminum wire; or even better compared the specs and end results (sound wise) vs copper wire? If the numbers add up with this, the very good thing I've found is that it seems that aluminum wire is a bit cheaper per pound/kilo, see here of what I've found: High Quality 42 Awg Magnet Aluminum Wire - Buy 42 Awg Magnet Aluminum Wire,42 Awg Magnet Aluminum Wire,42 Awg Magnet Aluminum Wire Product on Alibaba.com
Using Aluminum Magnet Wire to Simulate the Lower Quality Copper of Yesteryear?
Originally posted by rjb View PostI suppose the crux of the matter would be how to connect the aluminum magnet wire to copper hookup wire.
Can't solder them directly."One experiment is worth a thousand expert opinions...."
Here's something I found on the Elektrisola website regarding soldering aluminum magnet wire:"Soldering of aluminum is possible, but there are a number of critical areas that need tight control. Tenacious aluminum oxide makes most attempts to solder using conventional methods difficult. Flux must be used because of the rapid formation of an aluminum oxide layer, which is difficult to remove and prevents the solder from wetting the aluminum. The reason aluminum oxide is more difficult to remove compared to copper is because of its very high melting point of 2030°C, compared to the 660°C of pure aluminum. Another reason the aluminum oxide is difficult to remove is its high corrosion resistance value. Therefore, more aggressive fluxes are often required, such as an organic amine-based flux (up to 285°C), or inorganic fluxes (e.g. sodium hydroxide up to 400°C). An ultrasonic soldering bath may also be used to crack the oxide layer and wet the aluminum without the use of flux.""One experiment is worth a thousand expert opinions...."
Agree and add, back to the original point: any difference between resistance of, say, 99% pure copper of yesteryear vs. modern 99.9% copper is absolutely irrelevant (less than 1%) compared to, say, the diameter tolerance when drawn, the wire tension or the exact number of turns.
While copper to aluminum difference is in the order of 80% , definitely not what you want .Juan Manuel Fahey
Originally posted by J M Fahey View PostAgree and add, back to the original point: any difference between resistance of, say, 99% pure copper of yesteryear vs. modern 99.9% copper is absolutely irrelevant (less than 1%) compared to, say, the diameter tolerance when drawn, the wire tension or the exact number of turns.
While copper to aluminum difference is in the order of 80% , definitely not what you want ."One experiment is worth a thousand expert opinions...."
Originally posted by David King View PostA lighter weight pickup would also be nice but there are other ways of getting to that. Whatever you do find out I know we would all appreciate it if you would report back."One experiment is worth a thousand expert opinions...."
Originally posted by capehead View PostYou know I've been spending all day trying to find the proper specs of aluminum magnet wire; particularly it's ohms per foot/meter/ect ratings and I have yet come across anything relevant to the issue.
Resistivity Calc
FWIW, #42 copper is 1659 ohms/1000 ft and aluminum is 2522."Det var helt Texas" is written Nowegian meaning "that's totally Texas." When spoken, it means "that's crazy."
Originally posted by Jason Rodgers View PostHow about this info?
Aluminium wire ? Kanthal"One experiment is worth a thousand expert opinions...."
Originally posted by salvarsan View PostHere's a quick and dirty resistance calculator link for arbitrary lengths of wire, tubes, and strips. Use a non-copper conductor from the bottom select box.
Resistivity Calc
FWIW, #42 copper is 1659 ohms/1000 ft and aluminum is 2522."One experiment is worth a thousand expert opinions...."
If you do decide to try winding with aluminum wire, my suggestion is to do the terminations mechanically, using some variation of the old wire-wrap technique. Remember that? Little sharp-edged square pins that stood up vertically. You wrap the wire tightly a bunch of turns around the pin, and the corners cut into the wire in a whole bunch of little notches. Wrap it, test it, and coat it with epoxy to seal it up. I've never tried it with aluminum wire, particularly down in these little sizes, but it seems to me that this would be a simpler and more reliable way of terminating than using solder and flux.
Using aluminum wire is an interesting thought. There may be some odd pickup configurations and formulas that could use it.
Originally posted by Bruce Johnson View PostIf you do decide to try winding with aluminum wire, my suggestion is to do the terminations mechanically, using some variation of the old wire-wrap technique. Remember that? Little sharp-edged square pins that stood up vertically. You wrap the wire tightly a bunch of turns around the pin, and the corners cut into the wire in a whole bunch of little notches. Wrap it, test it, and coat it with epoxy to seal it up. I've never tried it with aluminum wire, particularly down in these little sizes, but it seems to me that this would be a simpler and more reliable way of terminating than using solder and flux.
Using aluminum wire is an interesting thought. There may be some odd pickup configurations and formulas that could use it."One experiment is worth a thousand expert opinions...."
