hi guys, i am in the process of making a strat style pup but need it as small as possible to fit inside the neck (the neck extends into the body), and i also want the top to be very thin so that i can put it inside a wooden cover and have the polepieces popping through and not having the actual coil too far from the strings.
what i am trying at the moment is putting the alnico magnets into a temproary bobin, with tape on it to prevent it from getting stuck itself (think it happened anyway) and then filled between the magnets with 5 minute adralite (an epoxy). i stopped it from running under the magnets by sticking tape to the bottom to create a barrier.
do you guys think this will work well, or have any better ideas? i will post back later when it has dried (im sure it has now, but im not at home)
