On vacation, but I have a request from a local luthier to have a look at a dead Gibson HB-L. From what I read, it was a Bill Lawrence design while he was with Gibson in the late 80's. The picture sent to me of the bottom shows a PCB type base which is consistent with what I see from other sources on the interet. I am assuming there are no electronics on the top side of that base. I am seeing 2 different DCR levels being quoted on the internet from various sources, one group in the +/- 9K range and another group in the +/- 14K range. I would have thought the lower range to be for a neck version, but they seem to show the "L" on the bottom of the baseplate. Since I won't be back in the shop for a couple weeks, I was curious about the experiences others may have had working on this pickup.
Gibson HB-L
I don't have any experience with these pickups but after a quick google search I am fairly confident that the L (bridge) version has the higher DCR and the R (neck) version is lower. I saw only one account that differed, and that was on eBay - consider your sources.
Unless that pickup set was very strange, indeed, then those are also logically the proper associations for the dcr .
If they are dead?
it looks like a good time for him to start over fresh, and an opportunity to sell him a pair of regular pickups?
Just Saying!
T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Just Saying!
T
I'm still hoping that at least one of the coils only has a broken lead so I can measure it up to get some good data for a rewind if necessary.Take Care,
Jim. . .
VA3DEF
Originally posted by cbarrow7625 View PostI don't have any experience with these pickups but after a quick google search I am fairly confident that the L (bridge) version has the higher DCR and the R (neck) version is lower. I saw only one account that differed, and that was on eBay - consider your sources.
Unless that pickup set was very strange, indeed, then those are also logically the proper associations for the dcr .Take Care,
Jim. . .
VA3DEF
I've got an HB-R/HB-L set that came out of a 1989 Les Paul Standard.
The HB-L measures 14,041 Ohms DCR (actually AC @ 120 Hz, but close enough), 8.171 H @ 120 Hz and the resonant peak is at 5234 Hz.
It's the bridge pickup.
Originally posted by ScottA View PostI've got an HB-R/HB-L set that came out of a 1989 Les Paul Standard.
It's the bridge pickup.Take Care,
Jim. . .
VA3DEF
Jim. . .
VA3DEF
Originally posted by kayakerca View PostThe magnet is in backwards in this pickup (slug side south, screw side south). Are the magnets reversed in your HB-R/HB-L pickup set?www.sonnywalton.com
Hi
The usual cause for these pickups dying is the coil ends are soldered directly to the pcb base, any kind of expansion or movement in the pickup causes the coil wire to snap (there's usually no slack on the wire going into the pcb, bad design!) You might be able to catch the coil ends and splice a little extra leadout wire, normally ends up melting the groove in the bobbin end standoff a bit. I have rescued quit a few of these pups before. Basically a dumb design made to be easy to manufacture and difficult to repair (what's new)
Good luck
Andrew
Originally posted by SonnyW View PostI repaired a neck version of one of these last month. The slug side was south, 9.04K ohms, resonant peak 5.9kHz. Don't know if that helps but it is data.Take Care,
Jim. . .
VA3DEF
Good luck
AndrewTake Care,
Jim. . .
VA3DEF
Geeze am I ever stupid some days! The original bobbins were wound CW not CCW, which means the polarity was correct with the slug side south and the hot lead as the slug winding start and the ground as the screw side start.
Geeze am I ever stupid some days. . .Take Care,
Jim. . .
VA3DEF
Happens to all of us.
Cheers
Andrew
Originally posted by kayakerca View PostGeeze am I ever stupid some days! The original bobbins were wound CW not CCW, which means the polarity was correct with the slug side south and the hot lead as the slug winding start and the ground as the screw side start.
