The split-able active EMGs actually contain two separate pickups, a stacked "single coil" and regular humbucker. Unless they changed them, they have separate outputs you can use at the same time.
Look at the PRS pickups; they are single coil size, not humbucker size. You probably need taller bobbins. Try stacking the bucker bobbins and winding with 42 gauge wire.
