Originally posted by big_teee
View Post
5 string p bass pickup
Originally posted by rjb View PostWhat type of magnets are you planning to use?
Relative permeability of neodymium magnets is near 1.
A cursory Google search on alnico shows a range of values of about 1.3 thru 6.7, depending on type, conditions, and who you ask.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
http://coneyislandguitars.com
Originally posted by David Schwab View PostI wouldn't use neo rods though. Too much string pull. Alnico is bad enough.
Please reference posts 4, 5, & 6
Post 4:
David King says the unmagnetized dummy slugs should have the same permeability as the magnetized poles- but he mis-remembers that AlNiCo has permeability close to air (i.e. relative permeability close to 1).
Post 5:
So Marko concludes that he should use plastic slugs.
Post 6:
I clumsily point out that neodymium has a relative permeability of 1, and AlNiCo has some higher permeability.
I didn't follow through and state what I thought was the obvious conclusion:
1) Since you are probably using AlNiCo magnetic poles, then use unmagnetized AlNiCo slugs.
2) If, for some reason, you are using neodymium poles, then use plastic slugs.
But yes, I would expect neo rods to be too strong for bass pickups.
EDIT:
This is all water under the bridge.
Marko has already built his 5-string P & split-J set, and they sound great.Last edited by rjb; 04-07-2016, 06:19 AM.DON'T FEED THE TROLLS!
