Those screwdrivers aren't cheap a HF 12V drill would do a fine job here for $9.99. I can understand why one would chamfer magnets by hand when you can order them that way for an extra .07¢ ea. I think a buffing wheel makes more sense but that would turn dark right away so the photo must be of a fine grit grinding wheel. I'd get a 400 or 600 grit for this job.
softening edges of mag rods
Originally posted by David King View PostThose screwdrivers aren't cheap a HF 12V drill would do a fine job here for $9.99.
Maybe because they are slim and easy to hold?It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
http://coneyislandguitars.com
Wet-Stone
Try just putting the magnet in the end of a drill and tighten. After it is inserted like a drill bit... hold the drill at a 45 degree angle and use a wet-stone with a little oil to soften the edge. In my opinion that is the Cheap Way to get results... Since you have a drill laying around and a wet-stone that costs about $5-$6 there you have it.. beveled edges ... There is no reason to use a (rig) of 2-3 different tools that you have to buy to do the job -Chris KP
I was thinking the same thing... but chuck it in a drill press. You can made up a jig to hold the stone at the correct angle.
Chinese made bench top drill presses go for about $50....It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
I use a grinder with a soft stone, and a modified large Xacto red plastic cutter handle to hold onto the magnet. I use the handle because I ground the end off one of my fingers once when my wife surprised me when I was beveling.
I tried the drill chuck method, but I don't because I don't want to get grit
in my drillchuck and wear it out.
Ken
