That bobbin fracturing has more to do with hole tolerance from the squish of extruded thread as is builds the part. Make the holes slightly larger to allow for the print. Basically running a caulk gun and anything that changes the gap between tip and plate will squeeze more material out the sides. Then pressure goes way up when the slug is forced in there. If all your cracks are on one side of the bobbins you might have the base plate slightly higher on that side, won't take much. Easiest solution is adjust the hole a little larger to compensate for the 'manufacturing' process. I have a small 3D printer and have had to adjust hole sizes this way.
