I've done the moving the rods up and down for years on my new strat pickups.
It only works on new pickups, not vintage pickups!
Tape the magnets well.(I use wax floral tape)
Wind the pickup, and wax pot thoroughly.
Put the pickup in the freezer, or refrigerator, for a little while.
Take out, and use a small mallet to adjust the rod up and down, while it is cold.
The rod will move, and the hard cold wax in the coil will support the coil and tape.
If the magnets aren't taped well this won't work.
It works slick !
Like mentioned earlier I mainly do it on the 4 middle rod magnets, not the ends.
After you are done, check with a ohm meter to see if any rods are shorted.
Try it if you want to, if you are scared of it, then don't try it.
T
It works slick !
T
