I just wound c. 6.9 kΩ (0,06 mm, AWG 42 or 43) wire to an old Seymour D. bobbing.
https://www.dropbox.com/s/vz4flqigew...91348.jpg?dl=0
1. It sounds a bit thin. If I coil more wire (2-3 kΩ ) do I get more bass? (f res goes down). I like the clarity of the PU.
It has now winded to "old specs", which should sound not so bassy. I tried to eq, and found that some 3 dB more bass would be ok.
2. I have an SD "Quarter Pounder" ( 11 kΩ) SCPB 3. It has way too much bass. What if I wind it to 7-9 kΩ ? Do I get more clarity and less bass?
