I've been seconded to make a few different 5 string J bass pickups. Some are unconventional and I can't source any 5 string J bass covers that are blank. My only option is to construct them out of wood or plastic. Any of you gents have some wisdom to impart on the subject? The bass is a Warmoth product with routes that match the contour of the pickup (i.e. not a rectangle) so my tolerances are going to be pretty tight. If it's going to be wood I suppose I could either build a 5 sided "box" from veneer (maybe laminate a couple sheets together for strength) and glue on the 4 mounting hole 1/2 rounds, or mill the whole thing out of a solid block. If any of you have done this before I'd appreciate some tips. thanks!
making J bass covers
You could make a simple mold and cast the whole thing in a black potting epoxy or polyester resin. What are the dimensions of the routs? You can buy blank 5 string shells that are 4.062" long, i.e. halfway between the Fender "extended" neck and bridge covers which are 3.95 and 4.125 respectively. There are also 4.5" long covers for sale somewhere because lots of other makers seem to have no problem locating them.
ooh, I never thought about casting in resin. I have some aluminum I could mill out for a mold but I'm not sure what I would use as a release agent. I'm also making a few different types of J bass pickups for him (with different magnets and sizes) so I would need a few different molds made up. Not sure if it's worth it. I'm meeting up with the owner on Monday to take measurements. It's a Warmoth 5 string deluxe J bass. the website says pickup sizes that fit are 4" for the neck and 4.125" for the bridge. My google skills must be off as I can't find any blank 5 string j bass covers. I would think the mounting hole spacing would need to be exact as well. Not sure if there is variation there among cover makers.
I also thought I could purchase standard 5 string covers from Mojotone and mill or sand the tops off and replace with blank plastic that I could drill out as needed.
I found this, looking around.
https://www.aliexpress.com/item/2-Pc...02.4.85.6c6Pr5"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Originally posted by StarryNight View PostMy only option is to construct them out of wood or plastic.
Good luck!
-Gnobuddy
I've had issues with air bubbles and final strength when using casting resins. They really need a filler material to give them strength. My preferred way to make covers is to use GRP and build a simple mould. I've used this plenty of times with excellent results. The advantage of this is it can be made really thin and still have plenty of strength - much stronger than any commercial cover. There's an infinite range of products available. I use paste wax as a release agent and if using a metal mould the cured object can be released in hot water more easily.
For limited production you can make a solid, dummy cover in wood, plastic or metal (or use an existing cover and fill the holes) and take a female cast off this (you need to lay up the glass on the inside). There are a number of ways to take an impression in rigid or semi-rigid materials. I've used silicone in a potting box to give a peelable mould. Once you have a female impression you can paint on the gel coat and let this go off before layering up glass mat or chopped glass.
well Jiminy Crickets! I thought I searched aliexpress but obviously not good enough. Dimensions look pretty good too. Worth a try at least. Thanks Terry!
Mick, I've been goofing with Fusion360 for a few months now. I could easily draft up a CAD model of these pickup covers. I don't know anyone with a 3D printer but I'm sure I could find someone. Interesting idea! Eventually when I get my CNC machine running I might be able to mill these in house with some decent repeatability. I'm still a month or two away though.
If you want to try casting, there is a wide range of two-part urethane casting resins available. I used to do a lot of model-making in the film and television industry and we used a few different resins from the Smooth-On company. I had a look recently at the Sculpture Supply Canada website Sculpture Supply Canada - Liquid Plastics and it seems the range of products has widened quite a lot, with some new resins that sound quite promising. We mostly used the SmoothCast 300 series, which give good results and are reasonably strong, certainly much less brittle than polyester. Task4 sounds like it might be a good one to try; it says it is good for cross-sections of .030-.050" and it is tintable, although the curing time is very slow.
With these types of resins it is important to use the proper silicone mould materials. Tin-catalised silicone is cheaper and gives good results, while platinum-catalised silicone will yield a longer-lasting mould. Mould release is generally not needed and the castings come out with a nice semi-gloss finish. Vacuum-degassing of the silicone, and pressure-casting the resin both go a long way towards getting good results. Nothing too fancy is needed for casting; we just hand-poured and then put the mould in a spray-painting pressure pot, and charged it up to 15psi or so.
Andy
P.S. Smooth-On is in New Jersey, so will be available from U.S. suppliers as well
I agree the 3d printing I've seen looks...not so good. As far as milling, I'm looking for any excuse to justify spending my ducats on this build. Don't ruin it for me David! I'm sure the fantasy will wear off soon enough when the machine goes dive bombing into a nice piece of curly maple.
as appealing as casting is, I would be starting from scratch. making the wood molds to make the silicone molds to make the parts etc. maybe it sounds daunting because I've never done it. I suppose I would need to somehow keep the magnets exposed while casting but still covering the top bobbin with resin...or I guess keep the magnets covered. but that might not work for the types of pickups I'm building.
seventh chord doesn't seem to have a minimum order (woohoo!) but shipping is between 39-59 days. Although further down it says 5-7 business days upon getting the order. hmm...
Originally posted by StarryNight View PostI agree the 3d printing I've seen looks...not so good.
But yeah, I agree, the best 3D printed surfaces I've seen don't even match up to the crude plastic toys at the dollar store.
3D printing is, however, otherwise well suited to the item you have to make - a shape that is complex enough to be a pain to make with conventional hand tools, and also contains no large solid volumes. Who said that pickup covers have to have glossy-smooth surfaces anyway?
-Gnobuddy
A couple of years ago I considered buying a Spinet that needed new quills. This one used nylon rather than porcupine and they were no longer available. I found a guy who had the same problem and he'd drawn them up for 3D printing. He tried every popular 3D printing material from different places and concluded that the strength just wasn't there. I've read this elsewhere - stressed parts don't hold up. Many places use the 3D printing as step in the manufacturing process, not for the final product. Maybe there are some good materials, but not within the reach of the average guy.
Originally posted by Mick Bailey View PostA couple of years ago I considered buying a Spinet that needed new quills. This one used nylon rather than porcupine and they were no longer available. I found a guy who had the same problem and he'd drawn them up for 3D printing. He tried every popular 3D printing material from different places and concluded that the strength just wasn't there. I've read this elsewhere - stressed parts don't hold up. Many places use the 3D printing as step in the manufacturing process, not for the final product. Maybe there are some good materials, but not within the reach of the average guy.
I'd have a look at nylon guitar or cello or bass strings, match the diameter & cut to length. Beats chasing down the neighborhood porcupine and asking him to give up a few.This isn't the future I signed up for.
I didn't buy it in the end - looked like it could turn out to be an expensive indulgence. Thinking back, I think they're called 'plectra' for the quill part. These were fitted into a longer arm ('jack', also broken) that had a felt damper. The problem I saw was that the plectra were formed as part of the hinged tongue, but only in the centre section of the keyboard and had to be replaced as a complete unit. All of the plastic parts were brittle. The top and bottom octaves were different, though and had replaceable plectra. But all needed fixing one way or another. I had a day to make up my mind on whether to buy it or not. Perhaps with more time and creative thinking I would have worked something out.
