Originally posted by David Schwab
View Post
Strat pickups are not usually wound that much. How would that make a humbucker sound like a Strat?
This is because you are using a weaker magnet, so you will get a duller (warmer) tone. That's not taking the other coil out of the circuit, unless you switch that coil out. The only reason you would get less string pull is from using a smaller magnet.
So why put the brass screws in there at all? They aren't doing anything, except maybe killing some high end due to eddy currents.
That's not a "coupling cap" ... that's a simple high pass filter.
