I'm have a customer that wants a humbucker for people who hate humbuckers. I have some 40 awg on its way. Also I plan to use A/8 for the bridge and A/5 in the neck. Any suggestions?
Winding a humbucker with 40awg wire. Any thoughts?
I tried 41 once, on a neck strat SC.
It was fine, but pretty bright.
I also tried 41 on some bass pickups, it worked fine for that.
40 is even bigger, and would be hard to get many turns on a regular HB.
Please let us know how it turns out?
I've wanted to try in the smaller other direction, and try some 42-1/2.
Remington Industries now sells it.
Had several circumstances where I thought the in between 42 & 43 would be ideal?
Also, since wire seems to come on the small size these days?
Todays 42-1/2 would probably be nearer to the 43, they used in days of old?
T
**https://www.remingtonindustries.com/...5-spool-sizes/Last edited by big_teee; 03-02-2018, 06:36 PM."If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Originally posted by Tikiman View PostI'm have a customer that wants a humbucker for people who hate humbuckers. I have some 40 awg on its way. Also I plan to use A/8 for the bridge and A/5 in the neck. Any suggestions?
If the customer hates humbuckers, what do they like instead? Fender pickups? P-90s?
Originally posted by Tikiman View PostHe basically wants an el Rayo clone.
I'm pretty sure the taller coils and
12 screw pole pieces will suffice ��
Originally posted by Antigua View PostGiven the fact
So, what are you even talking AT ALL here, uh?
Not a personal attack. Just because you keep preaching that ***you're all about the facts***,uh? OK, I just gave you ***THE FACTS***. Just the way you like it!And that'ìs a fact. Pun intended.
Pepe aka Lt. Kojak
Milano, Italy
Originally posted by Antigua View PostGiven the fact that there's not much of an apparent benefit to using larger gauges of wire, the low DC resistance of the El Rayo probably means that it's "under wound" similar to a Filter'tron. Filter'trons have a rather high output despite the low DC resistance, with 42 AWG. Their power (and of side-by-side humbucker in general) comes mostly from the fact that two coils are placed near the strings, and not necessarily the turn count. Filter'trons have less DC resistance, less inductance, and less flux at the string than a Stratocaster pickup, and yet you get a much louder output with them. I suspect the El Rayo is largely similar to a Filter'tron, but that's just a guess. They could be achieving low DC resistance through larger wire as you suspect, or by wiring the coils in parallel internally.
I am fully aware that these will be low dc. That is the point but my design has more steel in it with two keeper bars for the screws. My biggest concern is he wants four conductor wire. The coil tap will get thin in the skin I bet.
Originally posted by Tikiman View PostI took a guess with the 40 I’m hoping the taller humbucker coils I made will allow me to apply more wire.
Originally posted by Tikiman View PostI am fully aware that these will be low dc. That is the point but my design has more steel in it with two keeper bars for the screws. My biggest concern is he wants four conductor wire. The coil tap will get thin in the skin I bet.
