Originally posted by Helmholtz
View Post
Consider a pickup with four independent sections with an equal number of turns.
Upper section: Inner coil 1; Outer coil 2
Lower section: Inner coil 3; Outer coil 4
If you consider the inner coils being similar to a Strat type pickup, tall and narrow. Then you consider the Upper or Lower section coils 1 and 2 or 3 and 4 to being a short and flat pickup like a Jazzmaster or P90 type.
If you stimulate the pickup configurations with a drive coil or a vibrating string, would you have the same voltage output with either stimulation way or would the outer coil have less output being farther from the magnets?
If you consider the output of the total upper section compared to the lower section it is like the upper section is closer to the strings than the lower section and the upper section would have a higher output.
Creating a good mental model of a pickup shape supported by some measurements being done with a more realistic vibrating string or a stimulation coil should lead to a more deep understanding of the issues involved in this discussion.
How would you rank the output level from each coil in this experiment?
Joseph J. Rogowski
