but what if you turn the volume way down to where most of the signal is shunted to ground?
If the volume pot is wired as a variable voltage divider (as usual), the PU always "sees" the full pot's resistance.
Now would the pickup react differently if the volume pot itself was changed... say from 250K to 1M resistance?
As for what happens if you hardmount a pickup to a guitar instead of using springs or rubber tubing, EVH screwed his pickups right down to his guitar body with woodscrews.
Ken
Leave a comment:
