So sonic differences from pole piece material (if they really stand up to double blind listening tests) would be expected to be from the conductivity.
Dropping permeability of (1018?) fillister head 'bucker type pole screws
There won’t be a lot of difference in plain carbon steels used for magnetic applications.
https://en.wikipedia.org/wiki/Electr...d_conductivity- Own Opinions Only -
Originally posted by Helmholtz View PostFrom a table I found on Wikipedia, conductivity of pure iron is about 40% higher than that of 1010 steel.
In my past life, I had an equation for calculating the electrical resistance of iron as a function of the alloy content for low alloy electrical steel. P, Si, Al have strong effects, and Mn is weaker. All of these steels are decarburized.Last edited by Diablo; 01-09-2020, 10:42 PM.
Originally posted by Diablo View PostI don’t believe the value given in that table for pure iron. The value given for 1010 steel is correct and should be the same for pure iron.
E.g.: https://www.thoughtco.com/table-of-e...ctivity-608499
https://www.researchgate.net/figure/...fig3_228407964
https://www.thebalance.com/electrica...metals-2340117- Own Opinions Only -
Maybe this helps.
https://www.nde-ed.org/GeneralResour...ivity_Iron.pdf
The google books link doesn't show text.- Own Opinions Only -
Is the effect of conductivity strictly limited to eddy currents or are we talking about something else entirely?
This is the magnetic Skin effect (see Zollner, "Physics of the Electric Guitar", https://www.sciencedirect.com/scienc...04885300004145, https://www.researchgate.net/publica...ower_frequency )
The Eddy current rotating around the magnetic axis of the core produces a counter H field inside the core which reduces total flux. As a result the effective permeability of the core drops with increasing frequency.
Eddy currents increase with conductivity and so does the magnetic skin effect.Last edited by Helmholtz; 01-12-2020, 04:02 PM.- Own Opinions Only -
