I am rewinding a Schecter coil tapped pickup and some strange things are happening. First of all I’m getting inconsistent readings from this 43awg spn wire I ordered from Remington. I wind to a set amount of turns expecting a certain DCR but getting a reading much lower. The last attempt I wound and measured the wire before taking the bobbin off the winder. It read 5.7k. After assembling the pickup I’m back to a lower reading (4.2k)
Ok, here’s the weird bit. I’m measuring back and forth between the three lugs on the bobbin and decide to clip the start of the second coil (which is attached to the end of the first coil) to see if it is interfering in some way with the first coil. After clipping the wire I’M STILL GETTING A READING FROM THE SECOND COIL! Exact same DCR reading. How could there be a connection between these seemingly separate coils? It’s jobs like these where one needs to stop and go to bed and start again tomorrow. If anyone has any theories (paranormal or otherwise) I’m all ears.
