Surprised by inductance reading
  • smisco
    replied
    Originally posted by Antigua View Post
    I'd guess maybe the cores are different. 2.3H for 5.5K turns sounds reasonable if there are steel slugs or screws present. 1.86H sounds reasonable for 7k turns if there is no core at all, or a very minimal core.
    Good call Antigua---- I didn't even think about it---The 5500 turn coil had the slugs installed when I took the inductance reading and the 7000 turn coil did not. After pressing the slugs in place the 7000 turn coil now reads about 3.4H
    Leave a comment:
  • Antigua
    replied
    Originally posted by smisco View Post
    Both coils are humbucker bobbins with the same basic dimensions. One is wound with #42 plain enamel wire, a little over 5500 turns averaging 75~80 turns per layer--DCR around 4.3k----The other is wound with #43 poly wire , a little over 7000 turns at 95~100 turns per layer ---DCR around 6.9k ---I was thinking the coil wound with~7000 turns of #43 wound have somewhat higher inductance than the one wound with~5500 turns of #42. My meter shows the ~7000 turn coil at 1.86H and the 5500 turn coil at 2.29H, does this make sense?
    Leave a comment:
  • smisco
    replied
    Originally posted by Mike Sulzer View Post
    The ac resistances at 120 Hz, measured simultaneously with the inductances, should be very close to the DCRs. Are they?
    Yes, probably a little higher but not that much---
    Leave a comment:
  • Mike Sulzer
    replied
    This was measured with an Extech 380193 at 120hz---
    Leave a comment:
  • smisco
    replied
    You need to measure at a low frequency, such as 120 HZ, and your meter has to be capable of giving an accurate measurement with a low Q coil.
    Leave a comment:
  • Mike Sulzer
    replied
    Leave a comment:
  • smisco
    started a topic Surprised by inductance reading
