What part of the coil to tap?
  • What part of the coil to tap?
    Okay, let's say you wanted to make an overwound pickup and tap the coil at some portion of the total number of turns. Where would you prefer to have the effective portion of the coil be, the inner or the outer portion? That is, if you wanted to have a choice between 7000 and 9000 turns, would you make the 2000-turn difference be the first 2000 turns starting from the inside closest to the polepieces, or the last 2000 turns on the outside and furthest away from the polepieces?
    And why would you coose that option?
    Related to this, let's say you had a humbucker with, oh I dunno, 4500 turns on each bobbin, and wanted to tap that sucker so that each coil was reduced to 3500 turns. Would there be any virtue or added value to tapping one coil closer to the outside and the other closer to the inside?
    I say inner. You are closer to the core/magnets that way. The "extra" (hotter) windings go on top of that.
      Yes I agree. Once tapped you still need the inner coil to be in circuit.
      sigpic Dyed in the wool
        Another vote for inner turns here. Never seen it done any other way at least.
          Based on your replies, I feel compelled to ask: If my coil consisted of, say, 2500 "unused" turns close to the polepieces, and another 5 thousand "used" turns from that point to the outside of the coil, what should I expect to hear?
          My sense is that surely the inductance of that 5000 turns would be different when the circumference of those turns is greater, and that the DC resistance would certainly be greater than if I was using the inner 5000 turns and adding 2500 more around it.
          But should I expect less output when those outer 5000 are a little more distant from the polepieces?
          Could I help things out, if I decided to use the inner turns as the add-on, by using a thinner gauge for the inner turns, so as to minimize the polepiece-to-coil distance and overall outside circumference?
            What about doing the tap vertically, which is I guess is similar to a stacked humbucker that is not wired out of phase
              I think the problem there is keeping the upper and lower windings separate. Feasible, though.
                It's not a problem, just a matter of determining which lead will be ground and which will be tap. If you had a 10k single coil and tapped it at 5k, you could wire it for either 5k inner or 5k outer, just swap hot and ground.
                For a more realistic scenario on the specs, if you decided you wanted your tapped portion to be the outer turns, and say it was 7k tapped and 10k full, if the 7k is on the outside, it would probably sound a bit fuller, more bass response than if the 7k was on the inside because an outer tapped portion would be wider overall and see the longer bass wavelengths better.
                  Not hard at all.
                    I'm no mental wizard but it seems like inside next to the poles would be the most sensitive so you would want that main part of the coil close to the poles. With a single coil pickup (no bar magnets), the further the windings are from the poles the less they contribute to output, am I right?
                      Those bobbins look a little...noodley. j/k
                        You're probably right in theory, but I've never tried it so I can't verify. That said, the greater width of the coil might compensate some for the reduced sensitivity in terms of overall output. But again, just theorizing...
                          Steve Kersting's page has some nice FEMM simulations
                            Perfboard...
                              Two things seem to happen... as the coil gets wider, the outer wraps are less sensitive than the inner wraps, and the top of the coil is more sensitive than the bottom.
                              I made a stacked Tele pickup similar to the Jazz pickup in the photo, when listening to each coil separately, the top is bright and twangy, and the bottom coil is dark and mellow.
