Not the Allparts ones that have a sort of pyramid top and look goofy and the slot is big and slippery causing the screwdriver to slip out and gouge the surface of the bobbin. Anyone?
Source for GOOD gold polepieces
Andy C. from Tonerider had some nice gold polepiece screws but from what he tells me, he is not selling parts anymore because demand for his parts just wasn't there.
Originally posted by Zhangliqun View PostNot the Allparts ones that have a sort of pyramid top and look goofy and the slot is big and slippery causing the screwdriver to slip out and gouge the surface of the bobbin. Anyone?
Fortunately, I took several hundre of my nickel screws and had them gold plated.
WD
WDmusic has gold screws not sure if they are any good, I have to buy some. You can hand plate them with the Caswell hand plater, might try that one since I have the nickel kit....http://www.SDpickups.com
Stephens Design Pickups
Originally posted by Possum View PostWDmusic has gold screws not sure if they are any good, I have to buy some. You can hand plate them with the Caswell hand plater, might try that one since I have the nickel kit....
yeah it works but remember you're plating raw nickel on something so its dull grey plating. You have to have it dead clean too or it won't stick. I use it on slugs.....http://www.SDpickups.com
nah I don't polish mine, real nickel plating oxidizes back to grey anyway, I think most of the junk you buy is chrome plated not nickel.....http://www.SDpickups.com
Originally posted by WolfeMacleod View PostI've been raising holy hell with Steve at Allparts about these for quite some time. Remember my Screw fiasco last year? They're the same stinkign screw.
Caswell...
I just got my gold plating solution for their pen plater today and tried it out briefly. It does a pretty good job, its a bit hard to get it to plate in the slot, I tried dip plating and its easy to go too far and end up with an antique gold look, kinda like brass. Brushing it on give a bright gold. The solution only lasts 3 months so I figure I'd plate a bunch of screws in one session and store them for later use. If you can find good screws I'd recommend buying them alredy plated. I didn't buy the WD music screws so if anyone tries those let me know if they are the same bad AllParts screws.....http://www.SDpickups.com
Originally posted by Possum View PostI just got my gold plating solution for their pen plater today and tried it out briefly. It does a pretty good job, its a bit hard to get it to plate in the slot, I tried dip plating and its easy to go too far and end up with an antique gold look, kinda like brass. Brushing it on give a bright gold. The solution only lasts 3 months so I figure I'd plate a bunch of screws in one session and store them for later use. If you can find good screws I'd recommend buying them alredy plated. I didn't buy the WD music screws so if anyone tries those let me know if they are the same bad AllParts screws.....
