Just continuing the speculation a bit: if i chose the active way, i will run into trouble as soon as i manipulate the treble resonance of the pickup (which i intend to do...); the dummy loop should then act as a hiss generator... that's of course independent on the details of the implementation of the loop itself.
Low Impedance Pickup Research
This is a sticky topic.
Originally posted by bea View PostJust continuing the speculation a bit: if i chose the active way, i will run into trouble as soon as i manipulate the treble resonance of the pickup (which i intend to do...); the dummy loop should then act as a hiss generator... that's of course independent on the details of the implementation of the loop itself.
I would wire additional resonance shaping RC components in parallel to the series arrangement of PU+ secondary of CT (and not across the PU only). Will require smaller cap values because of increased inductance.
This way opposing noise EMFs can cancel "before" the filtering.Last edited by Helmholtz; 08-13-2019, 04:04 PM.- Own Opinions Only -
The circuit does not yet exist. The idea was using an "arbitrary" compensation coil and feeding that with inverted phase to an OpAmp based adder stage and doing the fine adjustment through the input resistance of that branch of the adder. . Which will lead to incorrect compensation if the treble resonance of the pickup is modified, just like in the passive case when You do NOT nose cancel before filtering.
At the moment i am using one half of a preci splitcoil, quite surprisingly with almost no audible impact on the treble resonance.
Concluding: the idea should work. It might, however, be useful to simply use more turns on the transformer, maybe 1500, and just one single loop. In conncetion with a High-Z pickup the impedance and also the inductance of the transformed loop will always remain uncritically small in comparison to the values of the pickup.
Feeding the singal of the loop into a separate input of an amplifier - as originially done by Alembic - is useful only if You do not modifiy the properties of the pickup, especially its treble resonance. In that case, the passive approach for attaching such a loop is preferrable.
Other topic: in this project i actually considered using a CT - based Low-Z pickup. I decided not to do. Reason: it is difficult to make them as narrow as even a tele neck pickup, and it would be less compact - just because of the size of the CT.
Originally posted by bbsailor View PostIf you are targeting feeding this pickup into a high impedance amp, you will need coils with 5,000 to 10,000 turns of very fine wire, assuming that there is sufficient magnetic coupling to transform the current into a useable voltage. Based on my experiments, I do not think this will work as there needs to be good magnetic coupling to get a good signal and to overcome noise that poor coupling would create.
Just wanted to let you guys know that I was able to get all the materials together to actually make the prototype as described two weeks ago... And, what do you know. It works! Kind of. I get some very confusing first measurements and results, though. Having the two rows of magnets and two sets of coils does not make it transparent as the configuration options seem to be infinite.
Fot this initial test I got two custom air coils measuring 2,2kOhm resistance each, about 8000 turns. Little 4mm neodymium magnets and a 4mm thick aluminium profile.
Some surprising results (to me at least):
- a single coil produces about the same amount of sound than combining 2. Either in parallel or series. I know sound is not linear, but still imagined there would be some noticeable difference.
- a single line of magnets produces the same sound as a double (opposing) lines of magnets, no noticeable hum difference either...
- a 500k pot has lots of hum in between the 3 and 7 setting. The hum goes away near 1 and 10 setting.
- the sound quality can be described as thin and pluncky and some combination of the coils does seem to allow for a slightly richer sound: A random combination produced a slightly deeper bottom end... (need more experimentation)
- the two coils combined read 4,4kOhm, either in parallel or series (?)
- the coils independent orientation/direction does not affect the results (?)
What I think I want to do, while continuing experimentation, is order 2x bigger coils, aiming for 8,8kOhm resistance combined. My thinking is it will potentially allow for more lower frequencies in the mix (?)
I'll upload some pictures if I get around to it this weekend.
Nick
Do you get about the same signal level using each of the coils separately (each in its designated position and using both rows of magnets)?- Own Opinions Only -
Nick
Yes, please post a photo so we can see:
1. The thick metal string loop, identify it's total length, size and metal type
2. The magnets within the string loops, plus identify their polarity relative to the strings
3. The coupling of how the string loop is going through the transformer lamination or toroid core opening.
Are your measurements DC resistance or impedance from using an LCR meter such as from using an Extech 38093 LCR meter?
Good photos and answers will allow any of us to offer better recommendations.
Joseph J. Rogowski
Originally posted by Helmholtz View PostThen your loop area needs to be at least 4 times larger than the PU coil area (with 2 turns).
As i did not find my Talemas (wer Ordnung hält ist nur zu faul zum Suchen) i ordered new ones. AX-500, AX-1000 and AX-1500. I think i'll start with a single loop of 6mm² wire and an AX-1500 in the bass i showed previously and if that's successfull i'll do a single loop with an AX-1000 in another recent bass with the same pickup. That bass is a LP JR DC shape, and its pickup cavity is much larger.
Unfortunately not success at all in the other bass. Same pickup, different coil geometry.
The noise even increases. On the scope the noise signals from the loop and from the pickup seem completely unrelated. A very slight reduction can be achieved when i connect the loop to the ground. So slight that you must really believe in an improvement ;-)
Still almost no correlation on the scope (btw: surprisingly weak also in the 1st example).
How to improve this?
The wavelength of the noise should be a non issue, shouldn't it? Or do i have to take into account some kind of interference patterns with a spacial wavelength of 1-2 decimeters which could explain different patterns of the noise field at the two coils?
Is there any possibility to improve the directionality of the compensation coil? Maybe by adding a "ladder" of wire pieces with an orientation of the pickup coil to the compensation loop?
Magnetic (interference) fields are polarized/directional and their orientation, phase and amplitude may vary strongly with position depending on source and distance of source. Far fields are easier to "buck" than near fields.
What are differences between the 2 basses and their circuits?- Own Opinions Only -
Presumably the transformer coils are shielded but I wonder if they are also oriented alike? If at all possible I'd superimpose the sensing and dummy loops as closely as possible.
Can you listen to the two noise signals so see what is being picked up and then move the instrument around the room and in different orientations. I wonder if your dual trace scope is latching onto the same frequency range for each trace. Hard to explain two totally unrelated signals when one would think 50Hz would predominate.
Originally posted by Helmholtz View PostIn this case I would try to reverse the phase/polarity of the transformer.
No relevance as the wavelength at e.g. 100Hz is 3000 km.
The pickup positions are the same. The location of the electrics cavity are different: Sharkfin has it in the upper horn, and Primavera in the usual spot below the strings. Which leads to a difference of the orientation of the compensation loops relative to the PUs: roughly 45° for Sharkfin and roughly 90° for the Primavera.
So it is not too surprising that the hum cancellation of the Sharkfin works better than in the Primavera. What IS surprising to me that the signals from the loop and the PU in the Primavera are completely unrelated. The compensation loop produces "just noise", while the PU signal has a dominant frequency spectrum.
And the CTs are unshielded as well.
Which didn't have any effect in the 2nd case.
or (if i'm in my rehearsal room) the field of the large toroidal transformer, not the 50 or 100 Hz hum.
[QUOTE]Which leads to a difference of the orientation of the compensation loops relative to the PUs: roughly 45° for Sharkfin and roughly 90° for the Primavera./QUOTE]
How this? Aren't the compensation loops in planes parallel to the PU coil planes?
That's why i specualted on interference patterns.
Do you have an LCR meter?
Not quite clear from the picture: Is the controls' cavity shielded against electrical interference?Last edited by Helmholtz; 09-12-2019, 08:27 PM.- Own Opinions Only -
The Sharkfin is Bass 1. Primavera is Bass 2 and looks like that:
last question first: the cavities and the channels are unshielded. Still unshielded. Will be done later when i make the active circuits. Anyway a guitar can and must be "sufficiently" silent without shielded cavities.
Strings are not grounded - grounding strings becomes useless as soon as soon as nylon tapewounds are used.
Refections (steel in the concrete of the nearby walln ?) can cause coherent sources.
But anyway - i am testing pretty close to computer, and there are many switching power supplies nearby. but there are also 3 lamps which can be clearly and uniquely identified as sources of electromagnetic fields. And moving the guitar in these fields has a strong impact on the noise. With or without compensation.
I checked the wiring, and the schemes are identical and correct. Also the DC resistance of the CTs are identical. The length of the primary wire varies ba about 20%.
LCR-Meter: one of my Multimeters has L and R ranges. At least large capacites seem to be measured well.
Angle: the planes of the coils are parallel to eacch other exept of course the windings in the CT. But the axis of maximal length are rotated in these planes.
(the cancellation effect of the problem loop was best when the plane of the compensaton loop and the planes of the pickup coils were at an angle of 45°. Which should not happen.)
For ever future step it is necessary to remove the coil from Primavera. Which i will do now.
EDIT: Measuring L gives 0.7 H for the loop, measured at the seconday ot the CT.
And something around 1.1-1.2H for the pickup. So the CT system should work, and the specs should be close enough for at least some humbucking.Last edited by bea; 09-12-2019, 11:33 PM.
