Does anyone have a source for humbucker alnico bars, that are cut to half length? I only need a small quantity to try out some designs
Half-length humbucker alnico bar magnets?
Originally posted by Meowy View PostDoes anyone have a source for humbucker alnico bars, that are cut to half length? I only need a small quantity to try out some designs
sorry i couldnt be much help.
Originally posted by David King View PostWouldn't a wet tile saw work for this? I'd use masking tape to remove all the fragments.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. Albert Einstein
Another thing you can do to catch those pesky shavings is to stick a neodymium flat magnet either side of the job. 90% of the shavings will stick to the neo and can be scraped off into the bin when you're done. I do the same thing when I have to drill an extra hole in an already populated (steel) amp chassis, too. Doesn't catch them all, of course, but better than nothing.So B+ is the one that hurts when you touch it, yeah?
I keep telling people about this little mitre saw. I use one daily for cutting everything from wood to alnico.
Now I'm well aware that it's a small under-powered gizmo but once again i'm telling you how to cut alnico easily. ignore me by all means. I have one which i shipped in to the UK. I wouldn't have wasted money on shit.sigpic Dyed in the wool
Originally posted by Spence View PostI keep telling people about this little mitre saw. I use one daily for cutting everything from wood to alnico.
[ATTACH]1657[/ATTACH]
Yes it is microMark and that's where I got it from. I'm well equipped for 110V too as I have a step-down transformer.sigpic Dyed in the wool
