I'm not sure how much would be needed. You know, just running the test signal through a differentiator would prob allow an ordinary power amp to be used. Very little power is involved here....
for a 500 turn coil say 1cm deep
i=Bl/munought*n = .005T *.01/(1.26e-6*500) = 79 ma.
Diameter does not matter for the field, but does for inductance.
That's for .005 Tesla...50 Gauss
Not much, huh? It's just that driving with the brakes on by using thevenin equivalent of a current source needs higher voltages than most amps can do.
A cheap power op amp like the LM12 set up as a transconductance amp would work too. The coil would be in the feedback loop. Old servo drive amps were made this way. In fact one of my cnc machines has 5.6KVA of transconductance amplifiers in it.
But a tester coil would need a power of just a few watts. And that is mostly imaginary power because it is a reactance. Only the DCR would consume any real power. I^2*r tiny....
Oh, by the way....check out the SPICE pickup response from Greg's numbers:
http://www.rickresource.com/forum/vi...&sd=a&start=15
