Turns Per Layer
  • #31
    I don't know if it matters, but looking at the analyzer plot, in the lower left corner, the large red sinewave is showing slope distortion on the back (right flank) of the negative peaks. This implies that the drive amplitude is too high for that frequency, and is causing an amplifier somewhere to become nonlinear, where the amp's max slew rate is insufficient to follow the signal. Asymmetrical slew rate limiting is common in operational amplifiers, so the fact that only the negative peaks are affected isn't surprising.
    • #32
      Originally posted by Possum View Post
      ...the neck is all glossy nitro...
      That's not going to affect the tone whatsoever.
      http://coneyislandguitars.com
      • #33
        That distortion occurs well away from where the the waveform should be changing the fastest. I think it is some other kind of distortion rather than slew rate limiting, although perhaps it could be if there is an instability involved as well. I also doubt that winding technique as described could make that much difference in the frequency response. That also indicates that there is something wrong with the measurements.
        • #34
          Funny thread.
          Sounds like (many have) forgotten their early learning in winding-101 class, wasn't TPL like the very first thing a guy experiements with after gettting a machine up-n-running and buying a spool of wire?
          (and writes it all down in their notebook for later reference)
          -Brad
          ClassicAmplification.com
          • #35
            (double post)
            -Brad
            • #36
              In practical opamps, slew rate limits depend on output swing, and the kind seen in the picture is common. While it's true that the max slew rate occurs around the center, this is a large-signal effect, so one must read opamp datasheets to know what exactly will happen. General theory won't be much help.
              • #37
                Bear in mind that if the signal is being differentiated by the coil system (and from the frequency plots it looks like it is) then the slew rate distortion will appear at the peaks instead of the zero crossings.
                • #38
                  I hand wind. On humbuckers I shoot for 100 TPL and expect a 10% tolerance in that. I just try and hit that 100 mark as often as possible. That is the ballpark I like. My tension varies on the wire I am using. 42 PE, I tend to wind tight. 44 or smaller poly, I use a looser tension.
                  • #39
                    Joe, I have been working with ic op amps for over 45 years, starting with the old Fairchild 709. I know what slew rate limiting looks like in theory and practice, and that doe not look like it. Furthermore, who would use an op amp that slew rate limits at 10 KHz considering what is available now? Such an engineer would be laughed out of the profession. Yes, there is a large signal effect there; that channel could be overloaded, as I believe the numbers indicate.
                    Slew rate limiting occurs because the gain of the second stage falls off with frequency resulting from the frequency compensation introduced by capacitance from the output to the input of the second stage. This increases the current the first stage must able to supply for full amp output as a function of increasing frequency The first stage is a fancy emitter coupled (or equivalent FET) stage. It has good linearity up to near the current limit. The triangleization of the sine wave is evident on every one I have examined (except in improperly compensated situations).
                    What I do not understand is why you decided it was slew rate limiting and now defend that. There is nothing there that indicates slew rate limiting.
                    • #40
                      10 KHz is slightly above the resonance; the impedance should be quite high. If the circuit driving the coil is an op amp current source, it would be easy to exceed the voltage limit of the op amp.
                      • #41
                        Because it looks like it. Not having this bit of commercial gear on our lab benches, that's the best any of us can do.
                        • #42
                          This shows slew rate limiting: RMAA Testing of Audio IC Op Amps
                          Scroll down most of the way. These test were done at 320 KHz with an output of about 3V peak. Only the ancient MC4858 (1.5 volts per microsec slew rate) shows a strong effect even at this high frequency. The others show more subtle straightening of the waveform.
                          • #43
                            Hi Guys, been a good while!! Hope all are well. In my observations and yes I hand wind but I have noticed something. Loose TPL and standard tension seems to darken the pickups. Tight TPL and tighter tension seems to me to brighten the pickups. I wound 2 buckers same turns on each one 4500 per coil, One was wound normal to loose tension with fast TPL say 45 to 65 the other was wound Slow tpl each layer tight against the other or as tight as I can get it hand winding and slightly higher tension and the difference is night and day, the latter was hands down brighter. I went so far as to increase the tension to just below stretching with the high TPL and it was even brighter but kinda sterile sounding. Was ok but really nothing to write home about. Hope this input helps the debate somewhat.
                            • #44
                              I always thought more scatter = less capacitance since each turn is farther apart? Less capacitance would make a brighter pickup.
                              Exactly! At least that's what I have found.
                              • #45
                                Originally posted by SteikBacon View Post
                                If a pickup is machine-made and is super tight turn to turn... Then the capacitance will work with less resistance, like in one turn. Scatter wound the wire will meet itself after many turns, more resistance. The machine-made should get the same (more even) amount of resistance vs capacitance spread through the coil, while scatter wound would spread the amount (but also have higher) resistance vs capacitance..
                                And machine wound will probably have higher number of this capacitance (wire is closer) than scatter.....
                                Higher capacitance will kill the treble, but so will higher resistance where the capacitance appears.
                                Does this seem right??
                                No, with a machine wound coil, Higher number of turns, or less scatter like you're trying to fill the bobbin across 1 layer all the way until you're done winding, will, as stated above by SteikBacon, make the capacitance lower as well as the resistance, as if you made 1 turn with a flat piece of copper the width of the bobbin all the way around. More scatter will increase capacitance because the wires overlap a lot more causing an increase in capacitance with resistance , think of it like having a 4 inch pipe, the tight scatter is like the water flowing through the pipe freely now imagine the more scatter where the wire goes over the other windings numerous times, imagine that those are like little baffles in the pipe, it's going to impede the flow of the water because you have more resistance. If you wind a coil with a lot of scatter you'll get to your desired resistance faster with less turns than you will with less scatter. I can't tell you how many times I've read this post and never got it. When I did it was like a light bulb turned on.
                                Basically, if you wind a little looser, don't confuse me saying looser with the wire being sloppy falling off the coil, with less scatter the pickup will brighten up. Less scatter and it will fatten up and cut some highs. The trick is to get the tension and the TPL just right for the best of all things combined. Don't take my word for it. YMMV.......
