In essence, what I want to know, is why would anyone need high output pickups at all?
As I understand it, the difference between a lower and a higher output pickup is in the number of turns of wire. The higher output pickup will have more turns, but this will also make it have a higher inductance, thus it will have a lower resonant frequency, and a "darker" tone.
I have noticed from experiments, that wiring a capacitor across a pickup will do just the same, it will lower the cutoff frequency.
Is this change in response different from having more turns? Wouldn't a high output pickup sound the same as a low output pickup with a correct "matching" capacitor (every other factor being identical, with matched levels)?
I've also read that higher output pickups are used to get more distortion.
I don't know about others, but I have never encountered an amplifier, or distortion stompbox that didn't have enough distortion when I turned the gain knob to 10. It's more like it was too much up there, even with lower output guitars.
If this logic is right, it is not the output that sets the limit of distortion, but other factors, namely mechanical microphonics, and noise level. A guitarist will keep turning up the gain until
a) it sounds right
b) the pickup squeals from microphonic feedback
c) the noise will be unbearable
So do high output pickups have better microphonic response then lower output pickups?
Do high output pickups have a better signal to noise ratio?
Am I missing something here? Or is "high output" just a marketing term used to sell bad sounding pickups?
(edit: okay, maybe not necessarily "bad sounding", but the high output pickup will still be less flexible)
a) it sounds right
