Originally posted by Mike Sulzer
View Post
One point to consider is that lower impedances are less succeptable to noise than higher impedances. If a low Z coil has 300 to 500 turns is has about one tenth the turns of a high impedance pickup and has 100 times lower impedance. Assume that the transformer is in a shielded can, which it is, then the transformer will pickup minimal additional noise mounted at the amp.
The noise induced in the 300 to 500 turns will be much less than 5000 or more turns of AWG 42 immersed in the same magnetic field. I can use a low impedance Alumitone pickup within 2 ft of my computer and monitor with no external noise. I can not do that with a high impedance humbucking pickup, as I must orient the guitar for minimal noise. Try it and see for yourself.
Joseph Rogowski
