Best way to widen P90 cover holes
  • Best way to widen P90 cover holes
    Trying to make a rod magnet P90 for a customer with rods larger than the holes in a typical P90 cover. The covers are kind of brittle for drilling and tend to crack or shatter.
    What's the best way to go about this?
    A reamer would work.
      Blunt drill bit , slow speed and make sure the cover is warm not cold..
      mick
        22 caliber rifle. Works every time!
        sigpic Dyed in the wool
          How much larger must the hole be? I've used swivel-tip deburring tools to enlarge holes in thin sheet metal.
          http://www.noga.com/nogaProducts.php?prdID=NG1003
            Check these rotary files, especially the Cylindrical Ball Nose, i use them on a Table router.
            Just lock the pickup cover hole over the tip of the File and wind your Router up through the cover hole.
            http://www.discount-tools.com/rfilesindexmain1.htm,
              Remind me not to make you mad, even from a distance!
                Ideally 1/4", but that's so big that the mount screws probably wouldn't fit between the rods so I'm having some rods made at a slightly smaller diameter.
                  That was my first thought. I suppose I would need a few bits of graduating size...
                    I use a tapered hand reamer:
                    http://www.hobbytool.com/index.asp?P...PROD&ProdID=28
                    -Stan
                    ...just transferring wire from one spool to another
                    Stan Hinesley Pickups
                    FaceBook
                      Don't worry, I haven't shot anyone for years and in any case I can think of at least one candidate way up there on the list before I ever get to you Zhang!
                        Originally posted by Stan H View Post
                        That's what I had in mind. A lot cleaner and more control than a drill bit. Regular twist drills don't always work well in plastic because of the rake angle on the tip.
                          You got that right...
                          The hand reamer looks like a winner though. Thanks boys...
                            I forgot to ask - how many holes do you need to widen, total? One can buy reamers for use in a drill press, and of almost any possible diameter. Likewise hand reamers. If one is making a lot of holes, a reamer of the correct diameter is very much faster than being careful with a tapered reamer.
                              thought they did away with personally-owned firearms in the UK....<ducks>
