Originally posted by David Schwab
View Post
Shaw Paf
Originally posted by NightWinder View PostThey are cast....They have been tumbled, I'm tellin' ya!!It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
http://coneyislandguitars.com
Originally posted by PoorMan View PostAnd the supplier is?
Would you consider selling a couple to a hobbiest?
Originally posted by JGundry View PostOh boy. Not sure yet if I want to give away the supplier. In reality it is a piece of cake for any magnet maker to do unoriented A5 but very few will do it. I have not even placed an order yet. The magnets I got yesterday were sample magnets from the manufacturer.
Thanks,
Dave
Originally posted by belwar View PostCan someone fill me in as to what exactly "un-ortiented" means? Even a brief description helps.
I probably messed some part of this description up in terminology or process but I think more or less I'm in the ball park with the explanation.
Originally posted by JGundry View PostOriented Alnico has the magnetic grains oriented in the direction of the poles for the magnet. So for a humbucker bar they would be oriented perpendicular to the pole faces on the long thin edge of the bar. This is done by exposing the magnets to a magnetic field for some part of the casting process to set the orientation. I don't know exactly when or how long but I believe it is done for a period of hours until the magnets have cooled sufficiently. Unoriented Alnico is not exposed to a magnetic filed during casting so as a result the magnetic grains are randomly oriented. A2 is unoriented.
Oriented materials must be magnetized in the direction of the original orienting field, or exactly opposite to that field. Unoriented materials don't care, but are weaker in all directions than oriented materials are in their preferred direction.
If one is planning to magnetize a bar magnet through one of its short dimensions, then either the bar has to have been cut from the oriented ingot such the the orientation is along this short dimension, or one must use unoriented alnico.
