What is this pickup? Single Coil, three wire
  • What is this pickup? Single Coil, three wire
    Mates....
    Just curious about some pickups I found in my friend's miscellaneous box of guitar stuff... There is a set of three single coil pickups, three wires, but they seem "taller" than your standard single coil pickup (the white one shown in the photo). Is this perhaps a dual in one case (opposite polarity magnets) or just one big magnet inside? I think the third wire might be for grounding the metallic cover?
    Thanks, Tom
    My guess is that it is stacked? Have you taken any resistance measurements?
      Pickup 1
      Black/Red - 7.71K
      Black/White - Open
      Red/White - Open
      Pickup 2
      Black/Red - 7.83K
      Black/White - Open
      Red/White - Open
      Pickup 3
      Black/Red - 7.99K
      Black/White - Open
      Red/White - Open
      • vintagekiki
        vintagekiki commented
        Editing a comment
        third wire (white) might be for grounding the metallic cover
      So then the white wire has no connection to the coil. Fair enough.
      continuity to the plate, then, as you surmised
        Thank you!
          3-wire pickups give the option of phase reversal switching (some refer to it a pseudo-phase). I sometimes do this for Tele customers with the neck pickup; disconnect the cover from one end of the winding and solder on a separate ground lead.
            https://www.tdpri.com/threads/whats-the-3rd-wire-on-single-coil-pickups.118954/
            Whats the 3rd wire on single coil pickups?
            https://www.tdpri.com/threads/3-wires-on-neck-pickup.203995/
            3 wires on neck pickup?
            It's All Over Now
