Noise gates don't get rid of noise, they just turn down the volume when you stop playing. So since the hum is always there, it rides up and down with the signal level. Too much gate and your notes get clipped off.
First pup build, I like the tone but not what I wanted
Amp modeling is fine for recording. You hear it every day on the radio and don't even know it. Live it tends to lack dynamics. I played in a band for a while with a guitarist that used an Apple laptop running GuitarRig and a powered PA cab. The tone was fine, but he always sounded like he was in the other room, no matter how loud he was. But for recording, where you need to limit dynamics anyway, it often sounds great. The only thing it can't do well is semi distorted crunch tones. But for my home recordings, I haven't used an amp to record guitar in about 25 years! The key thing is don't use the presets that come with amp modelers. They always suck. You have to tweak them quite a bit.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by Ward View PostJust say no to amp modeling.
I own the following modelers:
Behringer V-Amp2
Behringer V-Ampire LX-112
Behringer Bass V-Amp
Behringer V-Amp3
Fender Mustang II
Johnson J-Station
Boss GT-8
Roland GR-55
I've been able to make great presets with every and each one of them, and I've used'em both in studio and live as well.
I also have a hand-made "boutique" tube amp. It sounds great, but so do the modelers. I choose'em based on the venue. Big place, big stage, tube amp. Modelers in all other cases.
HTH,Pepe aka Lt. Kojak
Milano, Italy
