Hey guys. Just wanted to see if there's someone else who has encountered this and has a solution. It doesn't seem to be affecting the sound or anything, and it isn't really extreme, but it has been really annoying, me being the perfectionist and all. Any advice?
SC bobbin ends flaring a little, and not sure why...
I think it is from too much winding tension. Tighter makes a good sound, but it is easy to get too much tension when handwinding. I just posted a little analysis on this in another thread on warranty period for handwound pickups. The winding tension multiplied by 2x the number of turns is the compression force on the axis of the bobbin. It can be 990 pounds or so in a strat for 30 g average winding tension. I have measured that much on my winder with a gauge. I have heard of but never actually seen it that it can even break the alnico rods. Also it bugs me too. Looks bad. Mine sometimes tend to flare some, but so do a lot of the vintage ones I have seen photos of. - just my humble opinion.www.sonnywalton.com
Too much tension is one cause.
Another is loose forbon.
beveling magnets helps keep the forbon tight.
Sealing the bobbin before winding also helps.
I use Spray lacquer. That helps lock the forbon to the magnets.
Good Luck,
Terry"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Originally posted by David King View PostJohn,
I'm glad that worked for you. We should move this thread to the beginners section for future reference.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by SonnyW View PostI think it is from too much winding tension. Tighter makes a good sound, but it is easy to get too much tension when handwinding. I just posted a little analysis on this in another thread on warranty period for handwound pickups. The winding tension multiplied by 2x the number of turns is the compression force on the axis of the bobbin. It can be 990 pounds or so in a strat for 30 g average winding tension. I have measured that much on my winder with a gauge. I have heard of but never actually seen it that it can even break the alnico rods. Also it bugs me too. Looks bad. Mine sometimes tend to flare some, but so do a lot of the vintage ones I have seen photos of. - just my humble opinion.www.sonnywalton.com
