Pickup Specifications
    Originally posted by captcoolaid View Post
    I have a couple sets of the Neos tha stew mac carries as well as a couple of 200 pound neo dims. Yes they will pick up 200 pounds. I have them epoxied to a vice. I tried to charge by hand a a5 with them they snapped together so hard I was left with A5 dust. I have/had until it broke a charger, I need to get it fixed. I like the weight idea. Never thought of that one.
    The old Cliche, "Poor Boys Have Poor Ways" Comes to mind.
    I've done lots of mechanic work.
    I use deep well sockets, of different sizes for the weights.
    Works great.
    I prefer the smaller magnets like the StewMacs, and if you need more strength, I stack them.
    The very large NEOs are dangerous.
    The way I do things is very small scale and not for big Business.
    It's a fun Hobby.
    B_T
    Terry
      900 is unusually high for a humbucker type al5 magnet but materials can vary so if you want consistancy you have to check everything that goes into an assembly.
      You can degauss al 5 super easy- just rub a piece of steel on the magnet in the direction pole to pole or slide two magnets apart or like you guys said- use a ceramic so it is arranged south to south etc and pass it by about 1/8 inch away from the alnico. Touch them together and you can almost kill the alnico in one pass.
        The Pickupedia Site I had Links to, Seems to be no more.
        Here's the Gist of things on a PDF I had Saved before.
        Good Luck,
        Terry
        Terry
          Here are some Dimarzio Pickup Specs.
          I found this on another site.
          T
          Terry
            Well Maybe tboy is doing something with it. It was turing into a big SPAM site. I had to undo vandalism to the front page on almost a weekly basis.
              Originally posted by jason lollar View Post
              for instance an al 5 strat magnet fully charged will be between 1000 and 1200 gauss...
              sssssshhhhhh someone here could says that your measures are Nonsense and you need a new gaussmeter....
              here some pickup specifications ....
              http://www.google.com/url?q=http://o...y81KoASNUd989A
              .......my gaussmeter project..... ........
              .......first pickup with my cnc winder........
              .... NEW cnc pickup winder user manual.....
                the chart you linked to confirms the gauss readings I mentioned- did you read it?
                  He was referring to this thread:
                  http://music-electronics-forum.com/t27428/
                  I had made mention that the listed strength of the magnets was too low as read on my gauss meter. So Elepro was basically saying that you confirmed what we were trying to say in that thread.
                  Hence the winks.
                    OK, wait a minute. The alnico magnet turned to dust? Impossible. Did you ever try and CUT alnico?
                    Neos on the other hand will smash into a zillion pieces if you just let them smack together. Neos are not a solid piece of metal like an alnico. They are made from powder. They are VERY fragile.
                    Also, how did the neos snap together if they are epoxied on a vice? I use two neos in a vice and they aren't epoxied and they don't snap together, even if I close the jaws on the vice pretty close to each other.
                    This is all you need to charge alnico magnets. Each of these magnets will lift 20 lbs.
                      Please list Specs here!
                      Thanks,
                      Terry
                      Terry
                        oh- my bad- will catch up with the other thread when I can DOH!
                        • #27
                          Here is a PDF that shows different Rod Magnet Lengths for Fender Pickups.
                          There is a typo on the High E String, it is not the A String!
                          Terry
                          • #28
                            Dave I was joking about the dust thing. I had 2 200 pound mags for charging and prior to gluing them to a vice they snapped together and shatterd a A5.
                            Shut up and play
                            Peace and Tone The Rain Mann
                            • #29
                              Here is some Wiring Info for Les Pauls.
                              This could be put on the Guitar Tech forum.
                              However, Us Winders are Always wiring Guitars, and thought You may want to save this to your Hard drive.
                              The Old 50s, 60s, Modern thing.
                              So here they are.
                              I hope You can save these to Disk.
                              T
                              Terry
