Oh for craps sake. Wind with more tension an increase the scatter a bit. That'll take care if some of the harshness. Try even coils and see if you like that and if the highs are too subdued wind the slug a few hundred turns more than the screw coil.
Bridge Pickup Too Bright
I had a hard time getting the Frankenstrat 9.4k wind, on some bobbins.
10k should be very full, on most bobbins.
You could get 10k on the bigger GuitarPartsUSA bobbins, but they were taller and wider.
They just barely fit on a baseplate.
TLast edited by big_teee; 02-11-2015, 08:28 PM."If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Another consideration not mentioned is the steel parts. Experiment with different screws and slugs - 1010, 1018, 1022 etc. Metal matters.Bobby, www.TysonTone.com
