Originally posted by kayakerca
View Post
Addendum. . .
I truly do not understand the physics of this at all, but is it possible that the hum cancelling and tonal matching isn't a factor of DCR or turns, but rather the mass? If that were the case, then when the same wire is used on both coils, the ratio of either DCR or turns of the 2 coils would be representative of the ratios of mass, but again, only when the wire used was the same on both coils.
Probably way out to lunch on this as per usual.
![Confused](https://music-electronics-forum.com/core/images/smilies/confused.png)
