I recently bought a Supro lap steel on eBay; the description said "works, but needs strings and a knob". So, as soon as I got it, I plugged it in, and it did make some sound. It only had the 3 lowest strings on it, and the 5th string was not as loud as the 4th and 6th string. I was going to adjust the polepiece under the 5th string closer to the string, but then I found that one side of the slot was broken off (and that was probably because the polepieces are stuck in the pickup plate and someone tried to force it). So, I called Lollar Pickups to see if the had any polepieces that would fit (since Lollar makes a clone of that pickup); the guy that answered the phone put me on hold went and asked somebody. He came back and said "we don't sell those; maybe you should try a specialty screw shop". So I asked " could you ask somebody exactly what metal those polepieces are made of, because a diferent metal might have different magnetic properties". He put me on hold again, and when he came back he said "It doesn't matter, they're not magnetic". I'm not sure that's true; is it? In any case' I'd prefer to get the same type of polepiece or something similar. Does any one know where I could find something like that?
Another possible solution would be to get some penetrating oil, unstick all the polepieces, and file a new slot into the tops of the broken polepieces (the polepiece under the 4th string is broken too) ; is this solution feasible?
