I need to vent
I am new to winding. I have made about a dozen attempts and only 2 have have up with a reasonable DC resistance the rest keep coming up between 3.8 and 4.3. I am trying Tele neck and tele bridge pickups. 43 wire from Stew mac on the necks and 42 elektrisola on the bridge. I started with spray lacquer for the magnet poles after many attempts and reading on this forum I added Kapton tape over the lacquer, making sure no metal was visible. 8100 turns later I hit 4.3 again. I am assuming it is a short.
How do you keep the insulation on the wire?
Do I need to lube the edge of the spool?
Why after 8000 turns how do I end up with a short within a 500 ohm range again and again?
Is winding really that delicate?
I have built and/or refurbished over 30 guitar amps. I have build about 15 guitars. How hard can it be to get wire around a spool?
