Hey guys!
So I am in the process of building a custom guitar and I had the genius idea to make everything custom including the pickups. I tried the whole "winding your pickups with a drill" and after failing like 50 times I set the pickup winding process aside. I couldn't give it up all together since I already routed the the custom sized pickup cavities
Buying pickups at this point was not an option. Fast forward I made a pickup winder with the great help of my friends shown below:
![Click image for larger version
I am about to start winding my pickups which are as follows humbucker bridge and a stack coil neck pickup. I intend to have a coil split on either of the pickups with a push/pull pot such that the mid position on the 3 way switch would activate a single coil of each pick while retaining the humbucking effect. Having the switch on either the neck or bridge pickup along the coil split would give true a single coil experience. My custom bobbins have the following dimensions:
I got alnico 5s poles for the stack and a ceramic magnet for the humbucker and I got enameled copper wire 42AWG.
I got the stacked coil part according to this model:
I go the metal plate and everything.
SO.... I was intending to get some high gain metal sounding guitar with a versatile twist, hence the splittable stacked single coil.
I was hoping you guys can give me advice about the number of turns and approximate resistance I have to get to attain this metal/versatile pickups.
The other thing is I couldn't find info about matching a humbucker with a stacked coil as it is a rather uncommon configuration.
As a starting point I have a failed attempt of the stack where I wound ~9000 turns on the and that did not give a resistance reading however, through pointlessly complicated calculations, i concluded that 9000 turns on one of the coils of the stack should give approximately 7.96 kOhm and 9K turn on the hum coil should give about 8.45 kOhms
Can you guys help me, given the materials I have, get a high gain/metal humbucker with a stacked coil to make a good match or at least come close to this?
Thank you in advance!
![Big Grin](https://music-electronics-forum.com/core/images/smilies/biggrin.png)
![Smile](https://music-electronics-forum.com/core/images/smilies/smile.png)
