Greetings, Anybody know what's going on with PRS TCI technology? Is it a capacitor across one coil to achieve a dual resonance similar to dimarzio dual resonance? damping one coil with a capacitor? they sound clear in the top end, more high harmonic content. any theories?
PRS TCI?
Originally posted by singtone View PostGreetings, Anybody know what's going on with PRS TCI technology? Is it a capacitor across one coil to achieve a dual resonance similar to dimarzio dual resonance? damping one coil with a capacitor? they sound clear in the top end, more high harmonic content. any theories?Logic is an organized way of going wrong with confidence
In the Silver Sky model they are using a 300k pot and apparently putting a resistor across it in order to get a near perfect 250k resistance, apparently to make high tolerance into a selling point. They say that some pickups sound like "the voice of God" and some "just OK", and they assert that this ambiguity is due to poor tolerances. Thus going forward, all PRS pickups will sound like the voice of God.
As for the pickups, they obscure what they're doing with technical jargon about capacitance and inductance, also to the effect of tightening tolerances somehow. They claim the results are "very musical". We won't know more until someone provides some gut shots of a PRS with "TCI" technology.
Resistance: As is well known, adjusting the tone control when it is closer to 10 than 0 is like changing the resistance across the pickup. This modifies the height and width of the resonant peak.
Capacitance: The capacitance across the pickup and the inductance determine the resonant frequency. The cable provides most of the capacitance. The easiest way to tune the capacitance is to select a cable with the capacitance that sounds the best.
Inductance: This is determined by the design and production of the coil. Making consistent pickups requires consistent materials and winding.
If you say some of your pickups sound so much better than others unless you tune them individually, you are saying that you cannot make a consistent product, or just striving for a way to sell more guitars in a market where sales are declining.
- Likes 2
thanks for all the responses. i was looking more for a wiring trick, or cap across a coil or something...those tci pickups sound very open and articulate, as the reviewer in this video says https://www.youtube.com/watch?v=RjCKNed2f00
Originally posted by singtone View Postthanks for all the responses. i was looking more for a wiring trick, or cap across a coil or something...those tci pickups sound very open and articulate, as the reviewer in this video says https://www.youtube.com/watch?v=RjCKNed2f00
Originally posted by Jazz P Bass View PostIf you say some of your pickups sound so much better than others unless you tune them individually, you are saying that you cannot make a consistent product,
Then there's the matter of wood variability which shouldn't need elaboration.
What I see is PRS making 1st order corrections for industrial facts of life when no one else bothers.
-hizself
The truth is that pots can be tuned to precision, the way they did it, by putting a resistor across it to drop the pot value to a precise resistance, but that's not really possible with a guitar pickup, because while inductance is intentional, the resistance and the capacitance are "non ideal" side effects. There's only one plausible sense in which I can imagine the idea of tuning the pickups having truth; suppose they want the unloaded resonant peak of the pickup to be 5kHz, because because of all the variant L and C the resonant peak is instead 6kHz. They could add a capacitor across the pickup that drops the peak to precisely 5kHz. It would be sort of pointless to do that, because the capacitance will further change due to other parasitic capacitances elsewhere in the guitar wiring, but for the sake of selling refrigerators to Eskimos, it's technically possible. I'd have to see it to believe, none the less.Last edited by Antigua; 08-14-2020, 04:15 AM.
- Likes 2
Originally posted by singtone View PostGreetings, Anybody know what's going on with PRS TCI technology? Is it a capacitor across one coil to achieve a dual resonance similar to dimarzio dual resonance? damping one coil with a capacitor? they sound clear in the top end, more high harmonic content. any theories?Last edited by freefrog; 08-18-2020, 09:39 AM.
