What was ever decided on for a tensioner?
cnc winder controller board
Hello all I'm new to the forum and would like to show my interest in a group-buy. I,ve been sitting on the fence watching this project develop for while. Although I play guitar I admit I,ve no interest in winding my own pickups but do have interest in winding flyback transformers.
keep up the great work.
MikeLast edited by mikejn70; 10-08-2009, 02:20 AM.
Originally posted by David King View PostIWe could simply publish a PDF docs with all the holes that can be printed and stuck onto the MDF, wood, plastic, aluminum etc the person prefers to use. ....
If I were to use ball bearing I'd use the type that are already mounted on a plate (Flange bearing) for vertical mounting surface or in a pillow block for horizontal surface that will compensate for less than perfect alignment.
Like these...
POBCO TriMount® 2-Bolt Side Flange Metal Mounted Bearings
Spherical bearings (like those mentioned above) and flat or toothed belts are a good approach, as they can be made quite insensitive to such changes. And to minor errors of construction.
But tolerance of humidity and temperature changes and construction inaccuracy must be built in from the start.
Baltic birch plywood would be my first choice because I have tons of scraps laying around.
The 1/2" acrylic scraps from Tap plastics at $1/lb are another good option.
MDF, HDF are good because they are dirt cheap or free scrap at most cabinet shops and do a decent job dampening the stepper motor singing.
Top of the line would be 3/8" 6061 plate or 3/8" "L" section angle if you can afford it.
Thin aluminum will sing like a freight train unless you build it rigid with dampening or use rubber "O" rings on all the motor mounts.
I wouldn't be averse to cutting up birch ply and drilling all the holes on the milling machine. That goes very quickly once it's set up so cost is minimal and shipping weight isn't too bad.
The leadscrew, rubber hose connectors, leadscrew nut, end bearings and spacers would be part of the metal kit along with screws, washers nuts etc.
I'm happy to turn birch plywood faceplates with collars to fit the main motor. What diameter? 4"?
If someone wants to do a belt drive to get a higher speed then they can figure out their own transmission systems. The steppers max out at around 1000 RPM i.e. ten minutes per coil or less. That's just enough time to solder your leads and tape things up for the hot wax while the next PU is in the winder.
I want to test out some traverse ideas before committing.
What's the maximum coil height people need? Is 2" of traverse travel enough? Does anyone intend to wind 2 or more coils at a time?
I really like having a live tailstock that holds the bobbin on and slides out of the way in a hurry.
Oh and what's a fly-back transformer?
Found these http://cgi.ebay.com/Delrin-Flange-Nu...mZ330365030143
http://cgi.ebay.com/18-inch-3-8-10-R...mZ330365021048Last edited by David King; 10-08-2009, 08:00 AM.
about 9$each (for 20 pieces production) for the big brackets
and about 7$each (for 20 pieces production) for the small brackets...
each of ou would pay 32$ for 4 metal (3mmtickness) brackets..... (if you are 10)
Get a Real-Time quote for your bracket needs.Last edited by -Elepro-; 10-08-2009, 10:27 AM........my gaussmeter project..... ........
.......first pickup with my cnc winder........
.... NEW cnc pickup winder user manual.....
Originally posted by David King View PostDavid,
The tensioner is a solenoid that presses the wire between two pieces of felt. Up the voltage supply to the solenoid and the tension should go up. I don't know linear it will be but that's something to find out later.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by David King View PostThe tensioner is a solenoid that presses the wire between two pieces of felt. Up the voltage supply to the solenoid and the tension should go up. I don't know linear it will be but that's something to find out later.
Speed matters because a servo tensioner must be a factor quicker than the wire speed and tension pulsations from winding on an oblong bobbin.
The alternative is to use a very light and elastic dancer to handle the pulsations, so the felt tensioner need not be nearly so quick.
Originally posted by David King View Post...The steppers max out at around 1000 RPM i.e. ten minutes per coil or less....
Did you measure 1000-RPM or are you still using the flapping-tape guess method for RPM measurement?Last edited by RedHouse; 10-08-2009, 02:16 PM.
Originally posted by RedHouse View PostNot the motors Elepro suggested....
Originally posted by RedHouse View PostA tach on my test build shows it does 593-RPM max....Last edited by -Elepro-; 10-08-2009, 05:35 PM........my gaussmeter project..... ........
Brad,
I'll stand by my flapping tape method. When you misspend a few years of your life operating lathes you get tuned into things like spindle speeds. I can send you a motor or you can send me a tachometer if you're still in doubt.
I should point out that the larger motors can handle the full 2.4A and the motor resolution is much better at the higher current levels.
The motors that Tim W is selling were chosen by someone long ago to work with those drivers. They were all pulled out of some medical or scientific equipment that was scrapped when it became obsolete. Probably some engineer actually got paid to match everything up.
Benefit of the brackets is that they will help keep the motors cooler.
Elepro,
Are the brackets cnc drilled for that price?
I can buy a 12' length of 1/4" alu "L" bracket and saw it up for about 1/2 that price.
Originally posted by David King View PostI can buy a 12' length of 1/4" alu "L" bracket and saw it up for about 1/2 that price.
after my final test we will open a new thread.........my gaussmeter project..... ........
No holes on the thicker brackets, I don't have CNC or a cold saw for accurate cut length so jigging for holes would require facing the ends on the mill and jigging up for the holes, =more time and $.
The brackets will probably be happier with some wood pieces between them to build box shapes. What dimensions did you enter? Will there be enough room for motors, controller, drivers and X-former inside? We may need a little fan too if folks decide to enclose everything.
I'd like to think that people who makes pickups will own a drill press at least. The guys I know who want an automated pickup winder are all guitar makers and will have jointers, tablesaws, planers and routers too (but no money).
Originally posted by Joe Gwinn View PostAlso worry about how quickly the tension can be changed, as big solenoids have a lot of inductance, making it hard to change the current (and thus clamping force) quickly.
Dancers are fine but they always have a resonant frequency where they end up doing more harm than good. Dan (Immoderator) has suggested keeping 1-2 feet of wire between the tensioner and the coil to minimize localized stretching and breaking.
This tensioner is separate from the traverse. No one needs to use the tensioner if they have a different preference...
