Crock Pot Surgery!
  • #46
    What [does] the 1N5408 do to drop the temp in this circuit?
    This is a rectifier diode, so it blocks every other half-cycle of the AC sinewave. This cuts the power in half.
    • #47
      OK, so the Mini Crock pot is not usable for me, to pot pickups. It gets the wax so hot that it deformed an ABS bobbin so badly that I can't use it.
      I'm going to have to go back to my leaky paraffin warmer unless I can knock the temperature down.
      Oh well, at least it was cheap.
      • #48
        Make the 100Watt dim bulb tester, it takes about 30 minutes and a few bucks.
        T
        Terry
        • #49
          T
          Well I'm getting ready to move, so maybe after the move.
          • #50
            Hope the new place comes with a shop building?
            T
            Terry
            • #51
              T
              No, it will be smaller than where I live now, but there will be less people there then here, if you know what I mean.
              So I will have more room a better winding setup at least.
              • #52
                Here's a Pic of my 2 bulb tester.
                Not too pretty, I made it from scraps.
                I made it for amp work, but I'm finding it has many uses.
                T
                Terry
                • #53
                  Kewl! I was expecting something made out of those ancient porcelain closet light sockets.
                  The Blue Guitar
                  www.blueguitar.org
                  Some recordings:
                  • #54
                    How come no one has opened up the thermostat on the crock pot yet? It's probably a bi metal thingy. If so you could probably bend, test, repeat until it holds the wax at the correct temperature.
                    • #55
                      Don't have time!
                      Too busy trying to get pickups made to put in the Crock Pot!
                      I thought about getting another one to work on, til I got it right.
                      Then I could work on the first one.
                      T
                      Terry
                      • #56
                        You may use one of those $2 bimetallic temp sensors usually attached to heatsinks.
                        Maybe you even needn't *buy* one, but cannibalize one from a dead amp.
                        You bolt it to the bottom or side of your crockpot , your choice, waterproof the screw holes with some silicone rubber and, of course, do not forget to insulate the 120V carrying terminals.
                        You may even wire a neon lamp across the thermal switch legs to show its operation.
                        They usually trip around 75ºC , do the math.
                        • #57
                          Wouldn't a harbor freight router speed control ($9.99) keep a lid on a crock pot.
                          Someone needs to bite the bullet and hook up a PID controller PID controller - Wikipedia, the free encyclopedia (about $20) and take care of this problem in the most elegant way possible.
                          • #58
                            "PID Controller"
                            I read about it, and am still Wondering, "What to Hell is It"???
                            My crock pot, only cost a couple bucks on sale.
                            Hate to have to hook a Nuclear Reactor to it to control it!
                            T
                            Terry
                            • #59
                              Weeellll, it might actually *be* hooked up to a Nuclear Power Reactor, for all I know.
                              Although maybe through a 2000 mile power line, of course.
                              Unfortunately, the only abbundant power source left, for now, is Nuclear.
                              • #60
                                Dimmer control of crockpots
                                A crockpot with a hi-lo-off switch or a non-electronic bimetal controller can be controlled with an ordinary lamp dimmer. A large crockpot uses about 300 watts, half what the typical wall-mount lamp dimmer can handle.
                                If the crockpot has any electronics, no go. Unless you eviscerate it.
