I can understand and appreciate the desire to control every winding variable, and want to incorporate a reliable tensioning system, but for something as simple as a guitar pickup and lacking data on real world variation this discussion is bordering on swatting a fly with a sledgehammer. From a design standpoint, what I'm leaning towards is a purely mechanical system and allowing the tension to be set with a spring because it's simple and elegant. It would also be possible to determine the extent of any tension variation with minimal effort. If it becomes clear that a lot is going on then a more elaborate measurement system can be used. I'll be sure to leave plenty of room for the addition of servos, transducers, etc. to allow for modifications. My entire vision for this project is to make a very capable, flexible winder that will be reasonably accessible for just about anyone wanting to get into coil winding.
Part of my objection to using a cheap digital balance is that it strikes me as something that will end up being more of a pain to actually set up than it appears at first glance. It should also be possible to track down the actual component from a chinese manufacturer and probably get them for $1/ea.
As far as strain gauges are concerned, the properties of the beam will be needed first to determine the required specs. They generally cost less than $10. Also, the smaller ones I'm talking about almost always have pressure sensitive adhesive backing. It's really not a bad way of going, and it's not a CA and duct tape solution. Since I can't tell if you're being sarcastic or genuinely cynical it would be awesome if you wouldn't mind turning it back a notch or two... You have plenty of valuable thoughts and considerations, which I absolutely appreciate, but I can't get a read on you. I don't think there's anything I've said to insult you, and if I did in any way it wasn't intentional. In the design process I question a lot of things in search of the best solutions, and I never claim to be right all the time or assume that I am intellectually superior to anyone.
