Sewing Machine Coil Winder?
  • #91
    John....fantastic looking machine! I may do the same at some point....I have not wound anything on my machine yet, but Ive heard others say anywhere from 700-1200rpms it will stay accurate....It sounds like others have also had the best luck with rare earth magnets.
    -Erin
    • #92
      After much thought about how frustrating it would be guide wire from the bottom of the guide, I custom made a motor mount out of a piece of angle bracket, and reversed the motor. Worked like a charm! 2 rolls of wire (1 PE, 1 Poly) on the way....I should be winding soon!
      -Erin
      • #93
        Nice work! Looks like it's gonna be a champ! I've officially wound 8 pickups now with my winder and it is so much fun! Absolutely love the challenge of it, and the reward is extraordinary. When I plugged my guitar in with my new pickups and realized that they sounded better than my Dimarzio virtual vintage pups, I just about flipped! So much fun. Say, where did you decide to get your wire? Do you mind if I ask per lb. cost on those? I've heard rumblings that MWS wire is the only one manufacturing REAL PE wire, and I need to grab some of that stuff. I started with the poly since it is so much cheaper, and even those pups sounded better than my dimarzios, I can hardly wait to hear them with plain enamel! Good luck!!!
        John
        • #94
          I ended up ordering wire from Mojo. Spendier than MWS, but I didnt want to buy a 5lb spool! I think for both spools it was around $50+ship. I just cannot fathom buying/needing 5lbs of wire right at the moment. My first victim will be a dead/stripped Dimarzio super distortion. =) (I think I'll rewind it to something slightly less hot) BTW...I saved my original motor mount, that way I can put the motor back in its original position and reverse wind
          • #95
            You know, an easier way to reverse wind would be to put a limiter on the other side of the machine and wind from the other side. May be a little easier??? Good luck on the winding! it's tons of fun and very rewarding!!
            • #96
              John,
              I'll look into how to mount another limiter. Good idea!
              • #97
                I dont know why I didnt think of this befoe, but you could always mount your whole machine on a piece of plywood with it protruding a bit on either side and just make a mount for your limiter to attach to the plywood. when im doing stuff like this, my philosophy is to make as few attachments on a non flat surface as possible. But I'm also a little bit lazy. And want things to fit perfecc perfectly without too much modification or elbow grease!
                • #98
                  John,
                  Im of the same mindset. I dont like my own creations to look "hacked" together. Im thinking I could mount the limiter on the other side, low to the wheel....that may work. I can make a mount for the limiter that mounts right to the side of the box.
                  • #99
                    Here is the simplest one I have seen
                    Shut up and play
                    Peace and Tone The Rain Mann
                    • Originally posted by captcoolaid View Post
                      Even that can get the job done with good results ,with some fine tuning & practise ,,....nice....
