Hello,
I am still messing around with the Melody Maker pickups. With making a smaller neck and full size bridge, it has been very consuming of the time I can lay aside for the project. I have also routed out the cavities to accommodate the larger pickups. A new pick guard template was needed, at this point it is still being modified before final cut.
In addition I cobbled together a vacuum pump to pot the pickups. It is an olive jar with two holes to accept the vacuum hose, and a thermometer. You heat it in a pan of water just like a double boiler, keeping it off the bottom of the pan by using the part of a soup can you discard when you open it. When it reaches 140 degrees you remove it from the heat, insert the pickup, screw the lid back on and pull the plunger. The ones I potted feel like solid wax.
I hope this will be of help to some of you.
