I usually hang on the amp forum but I came across something I think may be of interest here. I "suffer" multiple avocations. One is making knives. A big part of many thermal austenitic steel treatments is cryogenic treatment. Well the clever dudes on some of the blade forums have figured out how to do it with commonly available materials! The best cryo services offer -300F. Some of the thermal treatment services that specializes in blades did a study and found that 95% of the advantages gained by cryo treatment can be obtained by reaching just -70F. A solution of dry ice and isopropyl alcohol will get down to -77F, is quite stable and the materials are easily purchased. So there you go. I can't make any recommendations on ratios or soak times so you guys will probably want to do some research of your own. I just know that some interest in cryo treatments has been expressed here and this information makes it eminently accessible for experimentation.
Cheers
Cheers
