Basically I've Been doing the odd custom pickup which sometimes involve cutting Alnico bars to size with a Dremel & using a fiberglass cutting wheel & I'm asking if there is something a little more efficient & a little quicker . thinnest kerf possible is a must .
What blades for Cutting Alnico ?
A diamond lapidary wheel used wet. They can be had as thin as 0.001", though thicker gives longer life. When used with a simple jig the cut is square and the edges don't break off. The finish is perfect and just a bevel needed to take off the sharpness. If you were on a budget you could use a diamond tile saw, though the kerf is probably too wide unless you can find one with a slim blade.
In fact thatīs how Alnico is cut or adjusted to size at the Factory itself.
Iīm not into pickups but make loudspeakers and learnt that magnets are cast to size as close as possible to save time and then ends are ground flat and parallel (what you need in a speaker magnet structure) with diamond wheels.
Way too hard for anything else.
In fact, Alnico IS a very hard Steel alloy, Iīm quite certain you could make dies or tools out of it.Juan Manuel Fahey
Originally posted by J M Fahey View PostIn fact, Alnico IS a very hard Steel alloy, Iīm quite certain you could make dies or tools out of it."UP here in the Canada we shoot things we don't understand"
I've cut it with a Laguna bi-metal bandsaw blade with no problem or discoloration (go slow and take pauses). I've also cut AlNiCo with a wet tile saw but, as mentioned, the wide kerf wastes material and causes excessive heating. A belt grinder has been great for small reshaping tasks.
Here's what I have been using lately, it is a mini- chopsaw with a 2 inch abrasive blade. The saw comes with a metal blade but I replaced it with the abrasive ones that I got separately. I have cut several dozen alnico rods without breaking the blade yet and that includes about 8 that were .250 diameter rods. (which is what I got it for) I haven't cut any bars with this one but I'm sure it would be fine for that too. I have used the dremel tool method a lot before this and I always was breaking the blades sometimes several on one cut. These blades are 2 inch diameter and 1/32 thick with a 3/8 hole.
https://www.amazon.com/TruePower-919...mini+miter+saw
https://www.amazon.com/Shark-Welding...JNXKWQ5QR80W30
Hope this helpswww.sonnywalton.com
Originally posted by Mick Bailey View PostA diamond lapidary wheel used wet. They can be had as thin as 0.001", though thicker gives longer life. When used with a simple jig the cut is square and the edges don't break off. The finish is perfect and just a bevel needed to take off the sharpness. If you were on a budget you could use a diamond tile saw, though the kerf is probably too wide unless you can find one with a slim blade."UP here in the Canada we shoot things we don't understand"
Originally posted by copperheadroads View Postlook a post #3
2 different elements are being mentioned, one is not called a saw by any description and *can* be had down to 1 mil thin; the other is called a "tile saw" , I checked a catalog and thinnest available goes from .01 to .019" thick, 10 to 20 times thicker than the first one, not surprisingly because itīs "something different".
But you seem to think they are the same, and ask about a .001" thick saw , which was never mentioned.
do you have a link or source where i can find a saw with the thin .001" kerf ?Juan Manuel Fahey
Here they mention .001" thick saws;
Diamond Lapidary Blades - SMART CUT technology
Probably the thinnest practical size would be this one - 4" diameter and 0.004" thick;
http://www.gemcuts.com.au/pro-slicer...ter-saw-bladesLast edited by Mick Bailey; 06-09-2017, 12:01 PM.
