Building a low cost Pickup Winding Machine
    I like this one - he says it needs a continuous rotation servo, but for a short push, I think a normal one will do
    STL files are here: https://github.com/tscha70/3DPrinter...arts_STL-Files
      I indeed was thinking about something like this: https://www.thingiverse.com/thing:2987762
      First thing first is the accuracy and the minimum step distance travelled.
        "Slop" in the mechanism could be beneficial - more randomness built into the scatter winding
        For more precision, there are steel rack and pinion parts on aliexpress - steel would be about £4.50 for the rack and pinion - molded plastic is also available, and would be more precision than 3D printed
        The other option is standard lead screw and nut with motor coupling - even cheaper would be threaded rod as used in cheap 3D printers
