Just reading some of the posts and I thought I'd share this idea. Just like my lathe winder, adapt something that already does most of what you want.
http://grizzly.com/products/G0538
A benchtop oscillating spindle winder. Simply make a tensioner/guide that mounts on the table, and add a counter/switch. Would probably need a speed control of some sort. I'm thinking that adjusting the traverse shouldn't be too hard if needed.
This ones about $150.00, a used ryobi or similar should be cheaper.
I've never looked inside one of these to really explore the idea. To me, if you are using a fully automated machine, then it's not handwound. Nothing wrong with that in itself....unless you are selling your pickups as "handwound" or "handmade" (which is generally percieved to be the same as "handwound").
