Temp controller for your wax pot .
  • Temp controller for your wax pot .
    These things work great for controlling the temp of your wax pot .I've been using this for a while ,I thought i would share .Cheers
    https://www.ebay.ca/itm/Inkbird-Temp...53.m2749.l2648
    https://www.youtube.com/watch?v=bV6VmaTwdHM
    I know this isn't a bargain, but I had one laying around for doing my guitar work and I actually use it more for potting than its intended purpose. I use cheap crock pots. A dedicated pot for a desired wax blend, an adapter for the power plug into this heat blanket controller. It works great.
    https://www.lmii.com/bending-heating...-120-volt.html
      Similar to what you are using, I use a variac to control the voltage to my wax pot, a small cheap crock pot. I know where I need to set it to achieve the temperature I want which I just check with a thermometer before I pot. Since I vacuum pot, I can't use a probe like Copper. Variac's are a pretty reasonable price as well.
      https://www.amazon.ca/YaeCCC-Transfo...NsaWNrPXRydWU=
      Take Care,
      Jim. . .
      VA3DEF
      holiganbet betturkey
