TalentCell battery problem
  • TalentCell battery problem
    Hi
    To power my self-built guitar amp, I'm using a TalentCell PB240A1. This has 3 outputs: 24V, 12V, and 5V (USB). The 24V and 12V outputs are centre positive. I'm using the 24V output to power the amplifier (which requires centre positive), and I'm hoping to be able to simultaneously use the 12V supply for my effects pedals. These pedals run on 9V and require centre negative. So I bought a small voltage reducer to step the 12V output down to 9V (checked out okay on multimeter), and I've wired my pedal cable to deliver centre negative (again checked with multimeter).
    With the TC battery just supplying the amp, that works fine. And with the TC battery just powering the effects pedals, but with a separate power supply for the amp, both work fine. However, when I power both the amp and the pedals from the TC, I get a high pitch whirring noise. So I'm assuming there's some kind of interference/problem with running these two battery outputs simultaneously. Any advice would be very welcome.​
