Hey folks,
I ran across something I've not seen before (see attchd drawing). I'm guessing the whole reason for the diodes in this configuration is so this designer did not have to use a center-tapped power transformer, but you tell me if I'm way out there.
I've seen where diodes are added in series with a tube rectifier circuit for protection, but my old brain is struggling with this configuration. If you were to remove the tube, the circuit should work just fine as a diode configured bridge rectifier. Now if the diodes that go to ground were the only diodes in the circuit, I can see where they might provide a 'virtual' kind of ground for the full-wave tube config. It would basically be a bridge rectifier with 1/2 of it being a tube & the other half being diodes. I can only surmise you would do that if you didn't want to pay for a center-tapped xformer , but why even incorporate a tube?
With all 4 diodes in the circuit, it appears the tube would basically be shunted by the diodes that are across it. Wouldn't the tube then be rendered ineffective?
Someone out there has probably seen this before.
BTW, this amp is having issues with it intermittently blowing the 100ohm virtual filament resistors. The amp now has all new but the rectifier tube. The other tubes are 6SL7 and 6V6. It did already blow the filament of the new 6V6 when it blew the virtual filament ground resistors I had just replaced. I'm using 1/2watt fusible replacement resistors so they won't smoke out when they blow. I don't have a 6X5 to try, but I doubt it's bad as it tests good & is not susceptible to tapping.
I just have a weird feeling that it's something involved with this unusual rectifier set-up.
Any ideas? Thanx, Glen.
No schemo for this amp, but it's pretty straight forward for this complement of tubes.
