Let's talk about testing capacitors
  • Let's talk about testing capacitors
    I have a bunch of new NOS and pulls of electrolytic capacitors. If they have obvious bulges, leaks, or are really old, then I toss them. What puzzles me is that sometimes a newish capacitor will test okay on ESR but lower than stated value on capacitance. Granted I am using a Fluke 87V to test the capacitance not a fancy LCR meter. At what point is the capacitance too low and I should toss them?
    I think the fluke is only reading the value and not testing it. You want to test get you an eico 950 or similar so you can test at rated voltage.
    nosaj
      Most new caps have a tolerance of +/-20%, and your Fluke 87V has an accuracy of +/-1%. So a 100 uF cap could read anywhere from 79 uF to 121 uF and still be within specs. Are yours reading farther out than that?
        As mentioned, the Fluke will only measure value. It can't measure relative goodness @ voltage. I have the same meter and no additional cap tester. But I don't do repairs. My own proclivity is to avoid NOS caps. Though there are some that are claimed to reform and test fine sold here and there. Unless you're willing to equip yourself with a capcaitor testing system that qualifies relative goodness for reformed NOS caps you could buy caps from these guys that do. Otherwise my boiler plate advice would be DON'T. The draw of NOS caps is the internet mojo and lore of OEM components. Since this is almost unattainable anymore anyway I don't see the point in troubling with it. And I don't think there's enough money to be saved in the effort for the end game. JM2C.
          And that's NEW caps. Old Mallories were either -80/+20 or -20/+80, I can't recall which direction the 80 was.
          Jusrin
            Main problem with long time ecap storage is leakage current.
            This will not show in capacitance or ESR measurement.
              Ok. To address the question directly, will you ever actually use those capacitors? I had the same dilemma. I had a bunch of old electrolytics I hadn't used. Then a project would come up and I would think "Alright, I have these caps." And then I would decide the project was more important than saving a few bucks for the risk of using the old caps and possibly having a problem. So then I'd buy new caps specific to the project. And the old caps remained in their caddy slots taking up space. I did finally toss them after rationalizing that I wouldn't really use them.
              If I have leftover caps after a project I'll keep them for a couple of years and then toss them. Sometimes I use leftovers but I don't trust them after about two years of disuse. So...
              Are you really going to trust those caps in a repair or project? Or will you decide to avoid the potential trouble and buy new ones anyway? If you're not going to use them they aren't getting any better sitting there.
                Regarding "leakage" ...
                I came across a four video series on YouTube where a guy builds a Capacitor Leakage Tester. Using his build ideas and box design, I came up with my own version of this (in lieu of buying an old Heathkit Cap Tester IT-28 or similar). In addition to the text box, I use a Heathkit 2717a Power Supply to provide the DC voltage. So my cap testing includes using meters to check the Cap value and ESR. But I also have this test box to check for leakage.
                Here is the video series on the Leakage Tester.
                Capacitor leakage tester design & build DIY - Part 1
                Capacitor leakage tester design & build - Part 2
                Capacitor leakage tester design & build - Part 3
                Capacitor leakage tester design & build - Part 4
Name:	Cap Leakage Meter.jpg
Name:	Atlast ESR70.jpg
                  I'm with Chuck. Are you really doing yourself any good trusting old, salvaged or unused caps? Would you really trust them? Are they worth the debugging time spent when one is marginal and develops high leakage in that repair or new project?
                  Electro caps have a shelf life as well as a working life. With no voltage applied, the aluminum oxide insulator "relaxes" and thins down. The capacitance goes up and the stable withstanding voltage goes down. New caps are formed up to a voltage that is mildly bigger than the rating so that they all pass specification. The withstanding voltage is a little high on new ones, because the oxide is thicker to allow for a few years on the shelf. Thicker insulation means the capacitance is a little low, too. In use, the applied power voltage on the cap is in the direction to repair any spots that get a little thin. So there is a mild self-repair mechanism in use. The cap still degrades, but more slowly, until it's decayed/self repaired to nearly equal the applied voltage. Over time, the decay wins, of course. But in use is better than on the shelf. Since the insulator is thinner, the capacitance goes up a bit.
                  Cap manufacturers specify shelf life on many electros.
                  It is possible to carefully apply a current limited voltage to old electros to imitate the original insulation forming process. This is the basis of much tube amp mythos, and can work to some extent if you're careful, and lucky. The working electrolyte in caps is not the same chemical composition as the original optimized oxide forming bath, so it probably doesn't work as well as a re-forming bath.
                  Electro caps are made by forcing an electrical current, carefully set up and limited, through bare aluminum foils. The polarity is set so that it causes formation of aluminum oxide on the surface of the aluminum. The current is used to force the aluminum to grow thicker layers than would happen with no electricity forcing it. The thicker the layer, the more volts the layer can withstand.
                  The insulation is not a pure insulator. Below some voltage, it allows only trivial leakage; this is the nominal rated voltage. Above that, leakage increases more rapidly with voltage. At some voltage, the leakage is so big that it forms hot spots in some places, and these places go into thermal runaway. Eventually it shorts.
                    Jusrin
                    Bonus capacitance at no extra charge (?!?) maybe up to 80% extra! These are the caps to buy. Where do you get a deal like that nowadays?
                    -80% would be plain unacceptable.
                      I get them in all those "aLl OrIgInAl FeNdErS aRe ThE bEsTeSt EvEr!" Amps I buy on De Farcebook.
                      Jusrin
                        Members.....
                        If I can, I would like to revisit my Post #8. I'm hoping someone can give me some hints on improving this circuit.
                        The one thing I did is to change the Discharge Cap to 1K, 5 watt. The original 47K took too long to discharge the cap.
                        Here is the problem, once the cap is charged, when I select the 100am position, there is a large surge of current and the meter pegs like crazy. It takes a tap for the meter to settle in. I am pretty sure I have a break before make switch.
                        Is there anything I can add to this circuit to add as a temp current limiter for the 100ma position?
                        And maybe the solution is that for the test, you never start in the Discharge position, you always start in the 100ma position (to prevent the surge)?
                        Thanks!!
                          Originally posted by TomCarlos View Post
                          [B]
                          Please explain how you're operating the tester.
                          I don't understand the circuit.
                          How's the cap charged?
                          Didn't watch the videos yet (too sleepy now).
                          Please note that electrical units are upper-case letters.
                            Please explain how you're operating the tester. I don't understand the circuit. How's the cap charged? Didn't watch the videos yet (too sleepy now).
                            Helmholtz and others -
                            Video Part 4, at 11:30 begins to explain how the tester works. While the instructions for usage are not clear, this is what I figured out.
                            I think the best way to use this tester is as follows:
                            • Power Supply Off
                            • Set dial to 100ma
                            • Power supply On and slowly raise the voltage to the desired voltage.
                            • Keep an eye out on the current meter at 100ma to make sure you do not have excessive current.
                            • Change dial to other settings to read the current (for lower current readings).
                            • When done, move the dial to the "Discharge" position.
                            • Lower power supply voltage to "0."
                            • Turn off Power Supply
                            • Allow 15 seconds for the cap to fully discharge.
                            When the Switch is in the SW1 A and SW1 B position, no voltage is applied to the Cap. You are at the discharge mode. And in that position, the meter is NOT connected to anything on the bottom end.
                            When the Switch is applied to the second to fifth positions (for both sides), voltage is applied to the cap through the meter. You then have the various shunt resistors that set the meter reading.
                              Without using the dedicated power supply or at least the 12k current limiting resistor the whole system makes no sense at all.
                              Rather you will damage your current meter.
                              Leakage current needs to be measured during charge up.
